Author Topic: How to get rid of these ugly marks??  (Read 4632 times)
kk0239
« on: April 09, 2014, 03:08:49 AM »
Guys i removed my new bat stickers rns larsons..
But it left behind the ugly sticker marks...
Can someone suggest hiw can i get rid of these marks..
Sent from my SAMSUNG-SGH-I337 using Tapatalk
tejasapatel
Re: How to get rid of these ugly marks??
« Reply #1 on: April 09, 2014, 04:26:30 AM »
If you have gum there remove it using goo-gone or de-solve-it.
After that some progressive sanding with
100 then 220 then 320 and finally 400 grade sand paper, you can go up to 600 if you choose.
Little bit of Sanding should make the bat face uniform in color.
- Ian Botham
kk0239
« Reply #2 on: April 09, 2014, 05:52:14 AM »
Sandind the entire bat? Or is it only in sticker area?
Along the grains or accross?
Jenko
« Reply #3 on: April 09, 2014, 06:47:09 AM »
Entire length of the bat mate and always with the grains
ItsJustCricket
    • Its Just Cricket
« Reply #4 on: April 09, 2014, 07:22:06 AM »
We use Pelican Release Non Sting Adhesive Remover, which Simon May kindly referred us to, for this kind of job.  We use it more for removing scuff sheets and stickers, but it should still work OK with this kind of residue, too.  Just be prepared to get your finger nails dirty!!
« Reply #5 on: April 09, 2014, 07:37:35 AM »
is the splice split on that bat?
joeljonno
« Reply #6 on: April 09, 2014, 07:40:39 AM »
Would be interesting to see.  I have had a couple of splices with black lines down them, similar to the above.  They have been fine and dandy.  They looked like a split, but wasn't.
Twitter - @joeljonno
tejasapatel
« Reply #7 on: April 09, 2014, 12:29:04 PM »
Yes entire bat even strokes through the blade and just a little sanding nothing crazy.
Here is an old SG I did last weekend.
I am no expert by any means, just doing it for fun after reading some threads on the forum.  There are a lot of good folks here who know a lot about bat and bat care.
- Ian Botham
Gingerbusiness
« Reply #8 on: April 09, 2014, 12:32:52 PM »
Mate, be careful.
I refurbished my RNS Larson Unik last year and the glue is ridiculous - rubber cement-like.
Went through a large number of rags, white spirit and sandpaper to get it off.
Just bear this in mind. It won't be the easiest of jobs but will EVENTUALLY come off :)
kk0239
« Reply #9 on: April 09, 2014, 02:06:34 PM »
Thnx for the tips tejas...
kk0239
« Reply #10 on: April 09, 2014, 02:07:51 PM »
Its a black line.. donoo what it is...
kk0239
« Reply #11 on: April 09, 2014, 02:09:41 PM »
Thnx for the tip.. unfortunately its not availble here in US :(
« Reply #12 on: April 09, 2014, 02:15:11 PM »
burn the glue off with a lighter?
kk0239
« Reply #13 on: April 09, 2014, 02:16:53 PM »
haha r u serious
« Reply #14 on: April 09, 2014, 02:18:59 PM »
im not sure :)
It sounds like it might work and then you can sand off any burnt bits that are left behind, if it goes wrong at least it will be good fun.
Everytime ive tried to get teh glue off its been a real pain. I found the best way is to scrape it off with a credit card or your nails (if you have any).
