Author Topic: How to get rid of these ugly marks??  (Read 4657 times)
kk0239
Re: How to get rid of these ugly marks??
« Reply #15 on: April 09, 2014, 02:40:14 PM »
Just to double check...
can i sand the bat face?
One of my friend said not to ever sand the bat face... is it true?
tejasapatel
« Reply #16 on: April 09, 2014, 02:52:54 PM »
You can sand the bat face.
I've done it on three bats so far this month and I've not seen a performance issues with any of them.
Be sure to Oil your bat and leave it for 24 hours after sanding it.
- Ian Botham
kk0239
« Reply #17 on: April 09, 2014, 02:54:04 PM »
Thanks tejas.. you've been a great help to me in this... :) .. appreciate it..
ajmw89
  • 4XI ornament
    • Wright Cricket
« Reply #18 on: April 09, 2014, 03:20:59 PM »
If solvents won't work, then the kind of  heat gun you use wfor wallpaper removal in short bursts works.  Hels having a spare pair of hands to use that though!
kk0239
« Reply #19 on: April 09, 2014, 03:22:48 PM »
I should only use dry sand paper correct?
Also looks like the sand paper is made of different types of material. which one to use?
Aluminum Oxide, Ceramic, Flint, Garnet, or Silicon Carbide   ????
« Last Edit: April 09, 2014, 03:25:43 PM by kk0239 »
tejasapatel
« Reply #20 on: April 09, 2014, 03:42:23 PM »
I got these from home depot  in different grits.
http://www.homedepot.com/p/3M-9-in-x-11-in-Final-Sanding-Sandpaper-25600NA-CC/202187741
They also have a multi grit pack that goes from 60-100-180-220.
I couldn't find a multi grit pack above 220 grit.
- Ian Botham
kk0239
« Reply #21 on: April 09, 2014, 03:45:34 PM »
thnx for the links..
does the material of sand paper matter?
kk0239
« Reply #22 on: April 09, 2014, 03:49:12 PM »
this is going to be first time i'm sanding the wood. so please pardon me for asking stupid questiuons :)
so, How do i know when to stop sanding?
nudgemaster
« Reply #23 on: April 09, 2014, 03:50:53 PM »
The finish will leave the wood willow condition same all the way down the face.
You should aim for a lovely smooth finish..
74           6/27
crictech
    • CricTech
« Reply #24 on: April 09, 2014, 04:17:46 PM »
you can use a little vegetable oil to remove glue residue. when you've got all the glue off rub the bat down so its dry then start with a low grit sandpaper, 60-80 and work your way up through the grits to a 220 or higher. I draw pencil lines on the bat after each grit then rub them out with the next one so I know I've sanded all areas equally
« Reply #25 on: April 09, 2014, 04:43:19 PM »
Today i refurbished a club mates bat to remove the stickers residue I used Rapide graffiti remover sprayed it on then wiped it off with a clean cloth residue came off easily.
junter97
« Reply #26 on: April 09, 2014, 07:03:33 PM »
Lots of good stuff on here for people who never done it before http://184.154.5.91/cbforum/index.php?topic=21474.0
