Author Topic: Asics poor build quality  (Read 1917 times)
fromthehip
« on: August 24, 2014, 06:24:41 PM »
I only brought these on 29th June so with the weather around this summer I doubt I've worn these 10 times
I also only use them to field in so not had much wear
Had asics before but never seen do this before
mp07
Re: Asics poor build quality
« Reply #1 on: August 24, 2014, 07:08:19 PM »
Are they made in Vietnam or China?  I had the same problem with my Asics running shoes...Made is China is still going strong and very comfortable, but new pair of made in Vietnam are not as good compare to the older version.
Giraffe208
« Reply #2 on: August 24, 2014, 07:23:24 PM »
That is a surprise, especially as they aren't cheap! I've never had a single issue with Asics in about 16 years of trainers and cricket shoes
cam66
« Reply #3 on: August 24, 2014, 11:29:33 PM »
any chance you put them in the washing machine to clean them because you cant do that to asics shoes
mp07
« Reply #4 on: August 25, 2014, 12:43:55 AM »
I never had Asics cricket shoes, but I noticed the quality difference in my Asics running shoes...newer ones are made in Vietnam and they are not as good as the older model made in China, even the fitting was off.
fromthehip
« Reply #5 on: August 25, 2014, 06:58:36 AM »
No not done that the other shoe is fine
I did notice when I got them that the glue was applied poorly
Like I said just used for fielding only I don't bowl so no toe drag either
I shall send back and see what they say
craigwm
« Reply #6 on: August 25, 2014, 09:30:54 AM »
The rubber sole on mine has started lifting. The only thing keeping the back corner in place is the screw in studs.
Howzat
« Reply #7 on: August 25, 2014, 10:38:42 AM »
The insole in mine is all messed up :(
Bat and Ball Cricket
« Reply #8 on: September 03, 2014, 10:14:10 PM »
Not sure if this is the case here or not, but there are cases where 'original fakes' (I'll explain the term) make it onto the market.
Essentially Asics put out their tender for a set of shoes. The successful bidder, fills Asics order, but then makes a second run of shoes themselves, not taking quite as long on their quality assurance (as there isn't Asics to check it before payment) and then flips them as fakes (but made out of the same factory and mostly the same materials as the original) for a bigger profit to them.
They look identical and basically are. Never quite sure unfortunately.
