Pages: 1 [2] 3 4
Author Topic: JVS HMX- issues and repair  (Read 12210 times)
smokem
Re: JVS HMX- issues and repair
« Reply #15 on: October 01, 2014, 09:23:54 AM »
Considering your initial photos and how much you try to promote Lekka on this forum, I can't believe you were asked to cut it up...
« Reply #16 on: October 01, 2014, 09:41:03 AM »
inside of the bat pics,
rather dry as one could see, crack is part of the initial break that wasn't sealed as it could not be seen until now
very dry willow even with 2 oils. cant even see the penetration
thanks - this really shows how dry these bats are - the inside looks like sawdust already! So the likelihood of them breaking is high - it also shows how hard it is to over oil a bat - there is no evidence of oil here at all (which surely will protect the bat!)
I was hoping to see evidence of the compressed fibres of the willow from the pressing process - up to about 3-4mm deep - but that isn't really clear
Still always worth seeing what the inside of a cleft looks like.
Please don't view this as a criticism of the product - I have used a few bats from that source and the have all performed very well
    • Neon Cricket
« Reply #17 on: October 01, 2014, 09:48:14 AM »
It was probably James' idea of entertainment - the bloke really does have a screw loose
TangoWhiskey
  • Review that.
« Reply #18 on: October 01, 2014, 09:55:59 AM »
I don't get it. Why would he only replace if you chopped it up?
    • Neon Cricket
« Reply #19 on: October 01, 2014, 10:04:55 AM »
Because then he gets a little bit more promotion on here...
Fearless Fly
« Reply #20 on: October 01, 2014, 10:13:20 AM »
Thanks buzz and 100% agree i am not surprised that it broke considering how dry it is. i disagree on the over oiling as a bat with a higher moisture content could yield a different result but certainly this bat could have had upwards of 5 oils but i only did 2.
TO answer your Tango, as James is not located in Australia and i am, he can only go on what pictures i send him and what I say.
His quote was that "if it was proper stuffed then i would have no issues of cutting it up" which i can understand even though it is strange.
He cant see that the ping had gone from the bat from his location but he can see that i have cut it up and turned it into fire wood.
Just James being James i guess
arsenal123
« Reply #21 on: October 01, 2014, 10:17:29 AM »
Just as an idea...
How about using each of the separate parts of wood to do different amounts of oiling.  E.g. one with a single coat, the next with two, three, four and another soaked in oil old school style?
Just so we get a better idea of penetration.
Fearless Fly
« Reply #22 on: October 01, 2014, 10:19:19 AM »
I like that idea Arsenal but as per James' request part of the agreement was to burn the bat which i did about 90 mins ago.... i do like that idea tho, i have a bat i could do this on
TangoWhiskey
  • Review that.
« Reply #23 on: October 01, 2014, 10:22:05 AM »
Burn it too? As if you sticking it back together would make it useable!?
arsenal123
« Reply #24 on: October 01, 2014, 10:22:31 AM »
Surely chopping it up was enough to ensure no use of it!!!!!!  ???
Fearless Fly
« Reply #25 on: October 01, 2014, 10:24:23 AM »
Correct boys i wasnt going to stick it back together but was interesting to see how EW burnt and especially a piece of willow that was so dry that struggled to burn.
« Reply #26 on: October 01, 2014, 10:47:58 AM »
There should be no need to prove the ping has gone. The bat has snapped in half and if it's happened within reasonable timeframe etc then there should be no issues in replacing it and no need to cut up and burn. Very odd request!
Let's hope the replacement lives up to your expectations of the brand
Fearless Fly
« Reply #27 on: October 01, 2014, 10:52:43 AM »
The ping of his bats are certainly good from my experiences,
The Palmist
  • Trade Count: (+15)
« Reply #28 on: October 01, 2014, 10:55:44 AM »
You could have just burnt it then, why bother with chopping and now that it is burnt are you supposed to send the ashes back. Were you to dance around the fire as part of the agreement also :-) and send a video.
This agreement sounds interesting and good on you to comply with it. My personal advice would be not to be a door mat next time.
The Palmist
« Reply #29 on: October 01, 2014, 10:57:19 AM »
what a waste FF could have used it as a net bat or personal defence bat or free loader bat.
Pages: 1 [2] 3 4
