Pages: [1] 2 3
Author Topic: ***New Forum Functionality - Member Mentions***  (Read 19342 times)
« on: November 21, 2014, 09:49:04 AM »
We have added some new functionality to the forum. This is the "Member Mention" or "Member Tag".
When typing a new topic or response, if you enter "@membername" in the text, the member that you have tagged gets a notification that they have been mentioned. When you type @ followed by the member name you are given options for the member name that you want to tag.
Mentions will show up in your profile, and you will see how many new ones there are as they show up in brackets next to Profile. Tapatalk also picks these up and will notify you that you have a mention.
By default, we have enabled this function to send an email to users. If you don't want to receive an email when you are mentioned, please do the following:
  • Go into your profile
  • In the left hand menu there is a new "Mentions" option - select this
  • Deselect the check box "Enable email notifications"
  • Save changes
« Last Edit: November 21, 2014, 10:11:03 AM by tim2000s »
Re: ***New Forum Functionality - Member Mentions***
« Reply #1 on: November 21, 2014, 09:54:06 AM »
@tim2000s
Testing...  :-[
« Reply #2 on: November 21, 2014, 09:58:45 AM »
@WalkingWicket37 Yes,  it works...
KIPPERS
« Reply #3 on: November 21, 2014, 10:29:20 AM »
@knobjockey ?????????????
« Reply #4 on: November 21, 2014, 10:41:39 AM »
@tim2000s when I click your name in the first one I tagged to you it is a link to your profile, none of the others have done that.
Is this right??
« Reply #5 on: November 21, 2014, 10:43:36 AM »
@WalkingWicket37 I think this is a downside/advantage of being an administrator or moderator, although this one allows me to click a link to the your profile so I'd suggest it is the way it works!
It's not mentioned in the release notes!
« Reply #6 on: November 21, 2014, 11:06:17 AM »
Thanks @tim2000s
The 2nd mention I received an email and the link works, maybe at the moment it's a case of
« Reply #7 on: November 29, 2014, 12:28:54 AM »
I've just got one. But clicking on the new button that says 'profile [1]' shows me nothing.
I've also checked back on all posts made this evening and don't see anyone mentioning me. Any thoughts?
A notification for quotes and mentions as well as showing the user where they were mentioned is a relatively easy hack on most forum software, admittedly I've never come across the one used by CBF but it should be well supported.
Number4
« Reply #8 on: November 29, 2014, 01:11:46 AM »
Did you go into profile then profile info at the top left then mentions?
« Reply #9 on: November 29, 2014, 10:24:59 AM »
Admittedly the 'profile [1]' notification has now disappeared, but this page showed me nothing last night. If it should carry a link to where you were mentioned and by who then i take back my previous point. :)
« Reply #10 on: November 29, 2014, 10:28:08 AM »
@Vitas Cricket I've done a little test for you. I don't know how well it works on names worth two words.  From the documents I've seen there may be some hot and miss.  It is apparently something that will be fully integrated with the next version of the forum software.
« Reply #11 on: November 29, 2014, 10:32:09 AM »
I looked at the post above before i checked the top of the page where the notification would appear, so perhaps i caused it to disappear before having chance to see it. Could you try again pretty please?
« Reply #12 on: November 29, 2014, 12:39:52 PM »
No, it was the same for me - nothing showed up.
« Reply #13 on: November 29, 2014, 12:48:59 PM »
Same here randomly get a 1 appear next to profile.  But sod all info once clicked and looked around.
« Reply #14 on: November 30, 2014, 10:37:19 AM »
Still getting random 1 appearing but no sign of what it means. Any ideas admin?
Pages: [1] 2 3
