Bats Consistently Breaking
Author Topic: Bats Consistently Breaking  (Read 3500 times)
ben147
« on: March 05, 2015, 12:46:53 PM »
Im new to posting on here so i hope this is in the right place for it,
Every year i seem to get the same problem in the nets my bat breaks, i know its recommended to get a net bat but i struggle to justify having 2 bats to myself due to bat prices.
Am i just unlucky that my last 4 bats have all broken in my first netting session of the season? is it the way i store them in the off season(in a room with constant cool temperature but isnt damp)? or is it just simply indoor netting?
Re: Bats Consistently Breaking
« Reply #1 on: March 05, 2015, 12:48:10 PM »
people use cheap balls, they cause issues
SLC
« Reply #2 on: March 05, 2015, 12:53:19 PM »
Buy a really cheap net bat then?
golden duck
« Reply #3 on: March 05, 2015, 12:57:18 PM »
As SLC says - I picked up a really cheap slazenger sports direct special for about £10 (in a sale, reduced from the lofty highs of £20 if I remember).
It's a bit lighter than I normally use with a bit higher middle, but I don't care about it so it can get bashed around, borrowed etc.
re you bats breaking - cant really help I afraid.  Cheap balls could defo be a factor though.  do the club not have loads of old matchballs that can be used?
joeljonno
« Reply #4 on: March 05, 2015, 01:01:15 PM »
If it is a bat that is used one season, stored, then breaks the first net of the new season it is most likely how you store it or the balls that are used.
How do they break?  Is it a piece of toe coming off, a split down the blade, the splice coming apart?
Depending on the breakage may give you further information as to why they break.
Twitter - @joeljonno
« Reply #5 on: March 05, 2015, 01:06:47 PM »
Yes you are unlucky to break a bat  every year Ben.  If its any help i never take my match bat to nets
Because has Pro cricketer has already said you cannot trust the quality of the balls used also you are more likely to toe end a yorker.   Even   if your bat doesn't break you can still cause damage.
arsenal123
« Reply #6 on: March 05, 2015, 01:08:23 PM »
Also hitting a yorker to an extent in nets won't help.  If you think the hard surface has no 'give' thus if you trap a yorker to some extent with your bat the damage is all going to be transferred to your bat rather than the hard floor.  Just a thought.
ben147
« Reply #7 on: March 05, 2015, 01:13:21 PM »
i do think a cheap net bat may be the way forward for me even though i never liked the idea of practicing with a different bat to the one i use in matches
And they all seem to break with a crack through the toe or edge
i12breakfree
« Reply #8 on: March 05, 2015, 01:26:22 PM »
Which bats have you been using ?
Cheap quality balls ,  aggressive shot making during nets can cause bat breakage. Do you guys have full pitch length in nets or shorter length which will lead to more pace during bowling ?
« Last Edit: March 05, 2015, 01:29:56 PM by i12breakfree »
« Reply #9 on: March 05, 2015, 01:28:43 PM »
you have stored it in a place that is too hot or too dry
« Reply #10 on: March 05, 2015, 01:35:58 PM »
I splashed out on a £25 MSR as a net bat.
I'm not risking one of my decent sticks against £3 sports direct balls on a hard floor.
You say you can't jutify a net bat due to the price, but if it saves having to buy a new bat every season surely a low range MSR/sports direct special/cheap Kashmir thing is a wise investment?
ben147
« Reply #11 on: March 05, 2015, 01:37:53 PM »
A Slazenger was G2 willow cant remember the details, 2 Warrior's (local brand in Wakefield)both were very good bats but opted for a change after they both broke after a season, most recent a GN Powerbow gen X players select
Full length pitch
ben147
« Reply #12 on: March 05, 2015, 01:39:28 PM »
Opps dont know how its all ended up in the quote, like i said im new haha
TBONTB
« Reply #13 on: March 05, 2015, 01:39:58 PM »
Go on eBay MSR, you can buy a good performing butterfly for 30quid in any weight.
i12breakfree
« Reply #14 on: March 05, 2015, 01:53:56 PM »
Full length pitch
And do you knock your bats?
