Pages: 1 ... 17 18 [19] 20 21 ... 48
Author Topic: ENG Test Series v WINDIES  (Read 139939 times)
alexhilly1492
Re: ENG 1st Test v WINDIES
« Reply #270 on: April 18, 2015, 06:50:37 PM »
im surprised mark footit hasnt been mentioned more 90mph plus and a left armer although a bit raw or is being at derbyshire a big negative?
BB: 7-4-9-5, 7.3-0-29-5
Manormanic
« Reply #271 on: April 19, 2015, 09:17:40 AM »
Firstly there was a journeyman like Tim Bresnan. No talent but tried hard. Then rocked up Chris Woakes and Chris Jordan, whom are both inferior to Bresnan.
Bresnan was - pre-shoulder and elbow injuries - a lot better than a bits and pieces cricketer.  Close to 90mph, heavy ball and capable of reverse swing he was the perfect third seamer, willing to do the hard yards whilst the pretty boys got the new cherry and pick of ends.  The fact that he was a perfectly functional seven/eight in Tests more than helped.
The last eighteen months of his test career were rather different because he just was not fit.  Woakes and Jordan are inferior copies of that version...
jwebber86
« Reply #272 on: April 19, 2015, 07:24:28 PM »
surely they should just pick alex hales in every format. problem solved
@james_webber
@dunstercricket
golden duck
« Reply #273 on: April 19, 2015, 07:44:56 PM »
222no vs Yorkshire, cane in at no 3.
Even with Yorkshire missing the test players it's a good knock.
Notts on 393/7 so hales has made a good chunk of them!
Personally I hope he has a really good season all round, for his own sake, ignoring how England like to mess players around
« Reply #274 on: April 19, 2015, 07:48:15 PM »
I think Woakes is as good as Bresnan he is a superior Batsman than Bresnan for sure and i think given a bit of time his bowling will come good too.
Give the lad time i think Woakes will be a decent fit for England but you are right Bresnan had his uses and was decent.
« Reply #275 on: April 19, 2015, 08:05:49 PM »
As i see it the problem with Woakes  is his lack of pace at Test level As an up and down bowler he won't bother the best players.
« Last Edit: April 19, 2015, 08:07:31 PM by Seniorplayer »
Manormanic
« Reply #276 on: April 20, 2015, 07:06:57 AM »
Being fair to Hales, he was still facing a decent attack - though you wonder how different it might have been had Sidebottom, Plunkett and Rashid been available to give it variety.
« Reply #277 on: April 20, 2015, 02:05:20 PM »
Woakes is neither slow, nor an up and down bowler! He's bowling quicker than both Broad and Anderson these days, has put a few yards on since becoming involved with England, and he has always moved the ball both ways.
Anderson and Broad both increasingly look like they're on the way to being shot out these days, I would have rested at least one of them for this series in the hope they can regain some fitness and sharpness, which would also have given the chance to include Plunkett for a little extra pace (although he isn't actually much quicker than Stokes) or give Wood a chance to prove himself.
Manormanic
« Reply #278 on: April 20, 2015, 02:43:21 PM »
Virgil was pretty sharp on Woakes' issue - its not lack of pace so much as the smoothness of his action, which means that the batsman knows exactly where the ball is coming from and therefore can pre-react more than he could with (the similarly paced) Wood.
« Reply #279 on: April 20, 2015, 03:39:40 PM »
When Vaughan talks about this stuff - the same with Trott's technique - he sounds like someone who knows about cricket, especially batting, which he doesn't always show in his "click bait" writing/bbc commentary.
« Reply #280 on: April 20, 2015, 04:37:22 PM »
Hadn't heard Vaughan's views on that, seems pretty fair actually - have noticed a similar issue with bowlers I've played with before. Definitely can't criticise Woakes purely for lack of pace these days though, he's pushing 90 pretty often.
« Reply #281 on: April 20, 2015, 04:58:00 PM »
Having watched Warks often
not  convinced Woakes has what it takes  with the bat or the ball to make it at test level.
Manormanic
« Reply #282 on: April 20, 2015, 05:31:48 PM »
He's similar to Jason Holder and Mitch Marsh - in that he's a decent fourth seamer who is not quite up to the job of third seamer, but almost good enough to be classed as the all rounder at seven.
« Reply #283 on: April 20, 2015, 07:28:55 PM »
So what's the XI going to be?
Cook
Trott
Ballance
Bell
Root
Ali
Stokes
Buttler
Jordan
Broad
Anderson
If it were my watch and bearing in mind reports of a pitch that will be relatively dead but dry enough to break up, it would be:
Cook
Lyth
Ballance
Bell
Root
Ali
Stokes
Buttler
Rashid
Plunko
Anderson
Gerry SA
  • Voice of the Voiceless
« Reply #284 on: April 20, 2015, 08:36:07 PM »
Clearly not. Holder, after he bulks up will be up at 140kph. Factor in he's 6ft7, he'll be a handful on any pitch.
"You should never get nervous about anything. What today seems important tomorrow isn't so any more."
Tito Vilanova (17 September 1968 - 25 April 2014)
