Author Topic: The quickest refurb I've ever done!  (Read 5361 times)
« on: May 12, 2015, 09:09:05 PM »
Evening all
As the saying goes "time is money". If that is true I could be a millionaire in 6 months! (Subject to an endless stream of jobs working 30 hours a day anyway...)
A fellow forumite dropped a bat into me today for a bit of TLC. Long story short, it's being collected tomorrow!
The bat arrived looking a bit like this
I came home during my lunch hour as I knew the bat was waiting. After a small amount of work I had the scuff sheet and most of the tape and residue off the face.
Re: The quickest refurb I've ever done!
« Reply #1 on: May 12, 2015, 09:13:17 PM »
That was about 13.45.
Fast forward to 18.00.
I got in from work and straight away got to work on the bat.
I got it back to white willow and assessed any further repairs that I needed to carry out.
The bat has been previously repaired, so there were only a couple of cracks to seal.
« Reply #2 on: May 12, 2015, 09:20:45 PM »
I sealed the cracks, let the glue dry and gave the bat a fine sanding.
As I skipped eating at lunch time (no mean feat for a fatty!) I had a break for some dinner.
In this time I left some bat wax on the blade to work its magic.
Then for the final touches, tape, re-application of the grip and a new scuff sheet.
Here is the end result.
And some indoor pictures with a bit more light.
And last but not least, the bat is back in its slip and ready to be returned to its owner.
One side note - I'm rather taken with the SafSleeve it arrived in!
I started working on this about 13.15 and finished at 21.35. I make that 8 hours, 20 minutes start to finish, with a break to attend my day job in the middle  :D
Bruce
« Reply #3 on: May 12, 2015, 09:31:02 PM »
Can't thank you enough.
I've had text and cbf messages all day updating me and asking what type of scuff I'd like.
Great service!
If you are Bournemouth/Southampton/Portsmouth way it's well worth getting your ole' faithful brought back to former glory
Thanks again
Chalkie
« Reply #4 on: May 12, 2015, 09:36:47 PM »
Great job Cam.
What stickers did the bat have and is there any way to reattach them on a bat after a refurb or do you always need new?
« Reply #5 on: May 12, 2015, 09:45:00 PM »
Thanks @Bruce
I just hope you're as please when you see it as you've been with the pictures.
@Chalkie the only sticker on this bat when I received it was the fireball one seen in the first couple of pictures.
I checked if it was okay to remove this before doing so.
As far as re-attaching stickers goes, I've been told Pritt Stick works, but I've never tried it personally.
I used PVA glue to re-attach stickers to the Piri Piri I recently refurbished and that went okay.
Another way I've been told works is to heat the stickers and remove them with a blade. To re-apply use PVA glue to stick them down, wrap in Cling film then apply gentle heat so it tightens round the stickers, pushing them flat and holding them in place.
« Reply #6 on: May 12, 2015, 10:03:56 PM »
Pritt stick does not work. I cannot see PVA working either as it is not possible for PVA to bond to pastic.. If anyone does have a solution to this problem I would love to know.
« Reply #7 on: May 12, 2015, 10:06:03 PM »
@joeljonno have the stickers all fallen off that Piri Piri yet pal?
A bloke on the internet said the glue wouldn't work, so that must be true...
Bruce
« Reply #8 on: May 12, 2015, 10:14:25 PM »
It had ''New Balance" stickers on it, sourced from an online auction site.
I may get some more as this years model also carry my initials (DC 1080)
sarg
    • CricketBatInfo
« Reply #9 on: May 12, 2015, 11:27:27 PM »
Great work on the refurb.
I do refurb work as a hobby and these days tend to leave the original stickers  and just sand around them.  I have found most stickers online are copies, take too long to arrive and don't stick. If they lift a bit of superglue fixes that. Most owners are happy with the results.
Its taken ages to source good quality scuff. I hate seeing it cracking. Got a roll of extratec now and am happy with the results.
kal_m
« Reply #10 on: May 12, 2015, 11:36:25 PM »
Excellent work that. Did you sand it by hand or did you use any tool?
Aspire and Achieve
joeljonno
« Reply #11 on: May 13, 2015, 05:57:05 AM »
They are still stuck down bud.
Twitter - @joeljonno
« Reply #12 on: May 13, 2015, 06:26:45 AM »
that is interesting as PVA works by being soaked into both surfaces and when the water in the glue is absorbed the glue is set. I cannot understand how the glue could soak into plastic. It is possible that it has formed a mechanical bond. How long have the stickers be on it for and how extensively has it been used since?. Cheers.
I am yet to try 'spray mount' as a glue for this purpose but it's properties may be better suited. Thanks for the sarcasm too.
« Reply #13 on: May 13, 2015, 07:34:34 AM »
I used an orbital sander to get the wood all one colour, from there the only tool was me sanding it by hand through the a couple of grades of paper to finish it off.
kal_m
« Reply #14 on: May 13, 2015, 04:39:30 PM »
Cool. Thanks mate. Once again, excellent work that!
Aspire and Achieve
