Poll
Which way round do you wear your pads?
Plastic buckles on the inside
Plastic buckles on the outside
Pages: 1 ... 5 6 [7]
Author Topic: Which way round do you wear your pads?  (Read 41296 times)
alexhilly1492
Re: Which way round do you wear your pads?
« Reply #90 on: August 11, 2017, 05:06:14 PM »
Buckles inside... plastic sounds more like a nick behind than a strap does
(My pads can only by worn that way)
BB: 7-4-9-5, 7.3-0-29-5
« Reply #91 on: August 11, 2017, 09:02:41 PM »
No idea what pads you have but this is clearly wrong...!!
alexhilly1492
« Reply #92 on: August 12, 2017, 08:27:59 AM »
Newbery tt and heritage spitfire.. (they're be same lad tbf)
They're both right handed sets I'm a right handed batter so it must be the correct way!
six and out
    • MKCC website
« Reply #93 on: August 12, 2017, 08:42:20 AM »
Surely your bat passes closest to the inside of your front leg when playing??
alexhilly1492
« Reply #94 on: August 12, 2017, 09:21:57 AM »
I was taught that ball hitting plastic sounded more like a nick than ball gittinf strap hence the buckle on the inside
leatherseat
« Reply #95 on: September 20, 2017, 09:01:03 AM »
Just to reinforce what others have said - The days of leather straps and metal buckles usually came with overlong straps. Even cut down there was generally an inch or two sticking out from the buckle. This gave rise to the possibility of the ball flicking the loose strap-end and the sound could be enough to suggest a nick on the bat, if they were on the outside. The current style of Velcro straps (so much easier, quicker and more comfortable) generally do away with this issue as the gripping area does away with the need for straps overhanging the edge of the pad.  I tend to stick with told style of strap-end on the inside of the pads, but don't think it matters either way. The whole question seems to be a hangover from the previous era of pad straps.
David
« Last Edit: September 20, 2017, 06:14:56 PM by leatherseat »
Tailendfielder
« Reply #96 on: September 20, 2017, 05:48:57 PM »
I was looking at the h4l pads but they are designed buckles out snd it is putting me off. Buckles in!
Woodyspin
« Reply #97 on: September 20, 2017, 06:18:56 PM »
Indeed they are! I was tge same until i tried them on
Biggie Smalls
« Reply #98 on: September 21, 2017, 12:54:46 PM »
What ? This thread is back from the dead ? I thought this was sorted - what I say is gospel ! Buckles outside , strap ends inside . The end . Nothing more to see here . Move along .  :D :( :D :D :D
« Reply #99 on: September 21, 2017, 01:03:43 PM »
Fat legs = buckles out
Skinny legs = buckles in
 :o
Biggie Smalls
« Reply #100 on: September 21, 2017, 01:11:40 PM »
 :o
What ? Why ? I have skinny chicken legs and put the buckles on the outside . Please explain .  :)
« Reply #101 on: September 21, 2017, 01:29:30 PM »
Too much lose strap to catch on each other, even when you loop it so the end is velcroed down.
I have relatively skinny calves and have never found a pair of pads when even half of the available 'opposite' velcro is actually in use.
Biggie Smalls
« Reply #102 on: September 21, 2017, 01:53:43 PM »
Ok fair enough.... i just don't relate to that at all . I have skinny ( i mean proper , marathon runner , skinny ) legs , yet i do my pads up quite loose ... the tip of the strap end never reaches the end of the pad , much less have any hanging loose . Maybe I've gotten used to wearing loose pads so as not to constrict my dodgy knee /legs with crap circulation.
« Reply #103 on: September 21, 2017, 02:27:51 PM »
That'd be why, like mines tight!
