Author Topic: Anyone using a narrower bat?  (Read 3578 times)
Contrails
« on: January 25, 2016, 09:43:19 PM »
G'day everyone,
I am currently having a discussion with Laver & Wood about this.  Planning to get a bat that is 10cm wide instead of 10.8cm as per the usual.  Reason being I would rather use the extra .8cm with beefier edges and middle for a given weight (2.10).  I am guessing 4mm either side is not going to make much of a difference (if I am edging it on a regular basis, there's a bigger problem and its not the bat) and the narrower blade should help with slightly higher bat speed provided the pick up is good.
What do you guys/girl think?
Re: Anyone using a narrower bat?
« Reply #1 on: January 25, 2016, 10:01:08 PM »
Difference in bat speed would be negligible
Edge size and middle size have a mainly placebo effect on performance in my opinion
I'd rather have a bat as wide as possible personally
« Reply #2 on: January 25, 2016, 10:02:15 PM »
Wouldn't a better option be full width, thinner edges and a full back rather than a narrower bat and unnecessary edges?
« Reply #3 on: January 25, 2016, 10:03:17 PM »
Rk made me a Harrow width joker style bat.
I don't believe the width had any effect on my innings when I used it. Mainly as it was sailing over cover for six out of the middle
JB
« Reply #4 on: January 25, 2016, 10:05:24 PM »
Think that'll be narrower than a size 6!
beaver5
« Reply #5 on: January 25, 2016, 10:07:36 PM »
Just get a harrow. I've got a H4L NV harrow that weighs 2.9 as my match bat for last season. It goes very well and it's just psychological about the width being less. I'm not very tall though, so this might be an issue if you are.
Contrails
« Reply #6 on: January 25, 2016, 10:11:50 PM »
Thanks for the quick replies.
Quote
I think you have hit the nail there. I will probably go with this.
Thanks again.
« Reply #7 on: January 25, 2016, 10:21:53 PM »
I use a 4 inch wide Harrow bat  and don't really see any difference to a standard S/H Losing over 3 inches or 8cm  off the width of a  standard  4 1/4  S/H wide bat seems to narrow.
« Reply #8 on: January 25, 2016, 10:40:10 PM »
What is the width difference between a SH & a Harrow in real terms? Isn't it approximately 2 thorough refurbs (but most on here don't keep a bat long enough for it to need 2 end of season refurbs lol)
The difference between a Harrow and a SH isn't noticeable straight away, I actually leant a Harrow to a teammate a couple of seasons back and he didn't notice until he compared it to a Short Handle in the same model.
That said, the idea of a SH length size 6 Width is a bit daft to me, but I need a bat as wide as I can get haha  :-[
« Reply #9 on: January 25, 2016, 11:02:03 PM »
Had to read this twice as though it was one of @FattusCattus topics for a while!
So you'd rather have a smaller surface area that's intended to hit the ball in order to have more wood on the edges and rear where you try not to hit the ball 🤔
Contrails
« Reply #10 on: January 25, 2016, 11:27:06 PM »
^^^ Now that you put it that way... Going with the regular width.  My timing is more dependent on how many beers I have had the night before.
Jenko
« Reply #11 on: January 25, 2016, 11:32:53 PM »
I think we are all guilty of wanting massive edges/profiled bats these days. Some of the biggest 6's I've hit are with traditional shaped bats with small edges and the bulk of the wood in the middle. My old lavers and SCATS certainly scored me the most runs of any bats I have owned.
Does it stop me wanting a huge bat? No. But when I think back nothing beats a well pressed, traditional shaped bat that I can still lift after batting for a couple of hours (this hasn't happened for a while haha)
Just my 2cents worth :)
Contrails
« Reply #12 on: January 28, 2016, 12:32:05 AM »
Nicely put Jenko.
Percy
« Reply #13 on: January 29, 2016, 09:04:09 AM »
Nicely put and totally correct IMO
Thesmiff
« Reply #14 on: January 29, 2016, 09:32:01 AM »
i've been thinking this myself. This fashion of huge deep lightweight bats. Isn't it the speed and weight behind the ball combined with timing that gives you the speed of the ball off the bat
