Pages: [1] 2 3 ... 6
Author Topic: DIY Grip Applicator (Vacuum)  (Read 123643 times)
SteffanLangholz
« on: February 23, 2016, 02:57:06 PM »
Vacuum Grip Applicator DIY Guide
Step one:
Go to your hardware store and puchase:
 - 1x 250mm long 50mm diameter pvc tubing
- 1x multiplier 50mm
- 1x decrease diameter from 50mm to 32mm (or whatever size your vacuumcleaners pipe is.
- 1x roll of insulation tape if you dont have it
Step two:
- Measure the length needed for your grip setup (harrow, SH or LH would be different)
- The pipe has to go on both ends of the multiplier, so you need to cut it, i used a hacksaw. Measure how much you need.
- The decreaser goes on the other opening (the 45 degree pipe)
Step three:
- Put it all together, tape any connection, sand down the edges and try it out!.
Oh- and by the way - it works on octopus Grips as well!
« Last Edit: February 23, 2016, 03:43:26 PM by SteffanLangholz »
northernboy1987
Re: DIY Grip Applicator (Vacuum)
« Reply #1 on: February 23, 2016, 03:07:20 PM »
Haha that's class! Good job mate :D
« Reply #2 on: February 23, 2016, 03:13:00 PM »
This is my most favourite think I have seen on here in ages.
right down to the fact I was irritated by the bar code sticker still being on the pipe!!!
liscon12
« Reply #3 on: February 23, 2016, 03:17:22 PM »
Where did you buy your piping from, was it from one of the larger DIY stores?
I fancy giving this a go :)
SteffanLangholz
    • Teams webpage
« Reply #4 on: February 23, 2016, 03:18:04 PM »
If it didn't work, I wanted to be able to return it ;-)
SteffanLangholz
    • Teams webpage
« Reply #5 on: February 23, 2016, 03:18:56 PM »
Just a random one.. In Denmark it is called jem&fix ;-)
SirScottiod
« Reply #6 on: February 23, 2016, 03:20:08 PM »
This looks really easy to do, thanks for this thread!!
All the No gear, No idea :D
northernboy1987
« Reply #7 on: February 23, 2016, 03:21:52 PM »
Any plumbers merchants (Graham's, PTS etc.) or DIY store like Screwfix/B&Q/Wickes will stock it pal
SteffanLangholz
    • Teams webpage
« Reply #8 on: February 23, 2016, 03:43:57 PM »
Tried it on octopus! Succes!
Mr_Orange
« Reply #9 on: February 23, 2016, 04:03:19 PM »
This is awesome. Definitely giving it a go
"A natural mis-timer of the ball"
« Reply #10 on: February 23, 2016, 04:04:57 PM »
8 likes! Could this become the most like post In cbf history!!
trypewriter
« Reply #11 on: February 23, 2016, 04:20:53 PM »
I think it needs a video as well.
northernboy1987
« Reply #12 on: February 23, 2016, 04:30:47 PM »
Liked it on badness now :D
bostoncricketer
« Reply #13 on: February 23, 2016, 04:31:39 PM »
You're my hero!
SteffanLangholz
    • Teams webpage
« Reply #14 on: February 23, 2016, 04:34:13 PM »
Next guy who makes it, should make a video!
