DIY Grip Applicator (Vacuum)
Pages: 1 ... 4 5 [6]
Author Topic: DIY Grip Applicator (Vacuum)  (Read 123644 times)
SteffanLangholz
    • Teams webpage
Re: DIY Grip Applicator (Vacuum)
« Reply #75 on: February 05, 2017, 06:47:03 PM »
Mine does have enough pull, 250 watts. But it doesnt pull quick enough to make up for the slight leak at the ends of the grip.
I've tried with my hands on each side, and it works perfectly.. Not sure what to do now.
« Reply #76 on: February 05, 2017, 07:09:27 PM »
Bigger tubing would lead to a tighter pull of the grip, the GM grip applicator also has some ribs on the ends to help with the seal I'd imagine.
Percy
« Reply #77 on: February 05, 2017, 07:39:23 PM »
I have a 3 CFM pump and a 50mm tube this will pretty much do anything and will cope with leaky grips. I did try various pumps before opting for the current one and anything that was either hand or battery driven didn't seem able to cope. Have done around a hundred grips with my setup and it has coped with every type of grip.  Let me know if you want more info.
« Last Edit: February 05, 2017, 07:41:27 PM by Percy »
SteffanLangholz
    • Teams webpage
« Reply #78 on: February 05, 2017, 08:17:57 PM »
Yeah, thats a better solution, but too expensive for me. It would set me back £70 with shipping. Cant seem to find anything local that goes without water..
« Reply #79 on: February 05, 2017, 09:05:18 PM »
I actually have mine working
It seems the end of the tube isn't creating a seal(maybe GM we're onto something with the ridges).
I used electrical tape to get a seal and the vacuum is pulled perfectly.
Vid coming up.
« Reply #80 on: February 05, 2017, 09:09:11 PM »
SteffanLangholz
    • Teams webpage
« Reply #81 on: February 05, 2017, 09:44:46 PM »
Vid coming up.
Then a new question arises. How to make a seal that works every time? Without tape that is.
« Reply #82 on: February 05, 2017, 09:55:06 PM »
Make a slight groove in the tube to allow an o ring to sit in?
SteffanLangholz
    • Teams webpage
« Reply #83 on: February 05, 2017, 10:25:00 PM »
Apparently I had a leak at the valve. I'm still using the original pvc setup, as I don't know a plumber or blacksmith. Loads of tape, and now it's perfect!
Might have to make a permanent seal though.
adb club cricketer
« Reply #84 on: February 06, 2017, 04:15:07 AM »
Nice !
