DIY Grip Applicator (Vacuum)
Pages: 1 ... 3 4 [5] 6
Author Topic: DIY Grip Applicator (Vacuum)  (Read 123673 times)
SteffanLangholz
    • Teams webpage
Re: DIY Grip Applicator (Vacuum)
« Reply #60 on: March 14, 2016, 02:16:49 PM »
I have no leakage.. At all actually!
Sent from my ONE E1003 using Tapatalk
« Reply #61 on: March 14, 2016, 02:36:21 PM »
Sorry to resurrect this but was hoping for some additional advice. I have built a similar "gadget"  for the club in metal and have it working off the vacuum cleaner thanks to Steffan. However, I really want it to be more self contained so am looking for a suitable vacuum pump but have no idea how powerful it would need to be. I have seen various different ones on the Bay of E and need to know if 2.5-3 CFM would be powerful enough. Would something like this work:
http://www.ebay.co.uk/itm/2-5CFM-1-4HP-220V-Single-Stage-Rotary-Vane-Deep-Vacuum-Pump-DE-fast-shipping-/161892851347?hash=item25b190de93:g:SSMAAOSwZVhWTtD3
Any ideas?
B3 cricket use a similar pump. So hopefully @The Doctor or @procricket B3 can confirm.
« Reply #62 on: March 14, 2016, 04:09:39 PM »
Come into a slight issue with mine.
My dyson!
It has a valve that opens when it detects a blockage, so it sucks the grip a quarter of the way and then. Boom, the valve opens and all pressure lost.
I need to find a shot Hoover or a vacuum pump.
« Last Edit: March 14, 2016, 04:14:49 PM by smilley792 »
SirScottiod
« Reply #63 on: March 14, 2016, 04:17:08 PM »
Made mine today.
Just used parts from my works van.
Very nice, very pretty :)
All the No gear, No idea :D
Percy
« Reply #64 on: March 14, 2016, 07:36:20 PM »
Here's my effort, just waiting for the right pump!
SteffanLangholz
    • Teams webpage
« Reply #65 on: March 14, 2016, 07:38:55 PM »
Seriously guys.. This thread was a diy threat. Not make an awesome product that out shows mine 10 to 1.
Percy
« Reply #66 on: March 14, 2016, 07:43:14 PM »
But without your idea of using a vacuum cleaner mine would be useless!
« Reply #67 on: March 14, 2016, 07:45:30 PM »
If you wanna go full DIY
Percy
« Reply #68 on: March 14, 2016, 07:49:24 PM »
http://youtu.be/oGb-UwAXicI
Too complicated for me!  I just want to buy one :) thats idiot proof!
Batbuddy99
  • https://royalascotcc.co.uk
« Reply #69 on: March 14, 2016, 07:53:09 PM »
My dyson!
Damn the ingenuity of the people that have revolutionised the vacuuming world! 😂😂😂
Sent from my Nexus 7 using Tapatalk
Percy
« Reply #70 on: March 23, 2016, 10:03:42 AM »
Well,  I have now acquired a vacuum pump from the Bay of E for the princely sum of £35 and its works brilliantly! The most difficult part is getting the grip stretched over both ends of the tube (I used 45mm tubing which may be too small for double grips, I hope not but time will tell)
For anyone else trying to do something similar I bought a 3CFM 1/4hp pump and its more than powerful enough. They seem to go for anything between £25 and £55 but if you hang around you can get one at a reasonable price.
This whole thing has cost me about £50 which includes pump, metal, welding, paint and felt base protector (so it doesn't scratch the Mrs' kitchen table!),  which is probably more than most people would want to spend but as this is going to be used by a number of people I wanted to build something fairly robust.
SteffanLangholz
    • Teams webpage
« Reply #71 on: February 05, 2017, 03:28:08 PM »
Whish me luck.. I'm doing this right now!
« Reply #72 on: February 05, 2017, 03:31:22 PM »
Good luck.
I purchased a small vacuum pump in an attempt to make a small carry round item. Unfortunately I either have a leak or the pump isn't good enough.
Will try get some pictures up this week.
SteffanLangholz
    • Teams webpage
« Reply #73 on: February 05, 2017, 04:03:56 PM »
Good luck.
I bought a 12v compressor, and epoxy welded a 4mm output to the air intake. Keeping the compressor function, but allowing for a vacuum to take place. Hopefully. Epoxy drying as we speak.
« Reply #74 on: February 05, 2017, 06:13:55 PM »
Ignore the long stainless tube and the excessive clear pipe. My stainless cutter is in the van so it's just like this for testing. Pipes will be curt down and meet each other were they currently are.
Idea was that's a 12 volt vacuum pump, so was gonna firstly have a fag lighter wire on it to use from your car, and at a latter date retro fit it with a 12 volt rechargeable battery.
Quite compact, not heavy and just makes abit of noise.
But currently struggling to get enough pull to stretch a grip enough.
Not sure if there's a leak, the tubing is to long, or the pump just isnt manly enough.
Hoping to do more testing next weekend.
