Author Topic: Does the kook ghosts edges taper! Findings inside  (Read 5554 times)
« on: May 13, 2016, 09:42:47 AM »
Do the kook ghosts edges taper....
Well I'd say yes, but we are talking Max of a mm either side. So 2mm in general.
Will this have an effect on a bats performance? Not at all in my eyes.
:edited m and h bit out as I knew it'd be a stretch for people to stay on topic.
« Last Edit: May 13, 2016, 10:11:40 AM by smilley792 »
SirScottiod
Re: Does the kook ghosts edges taper! Findings inside
« Reply #1 on: May 13, 2016, 09:49:35 AM »
That M&H makes me feel sick!! Its ruddy awful!!
All the No gear, No idea :D
« Reply #2 on: May 13, 2016, 10:00:45 AM »
I have a mate with an custom M&H like that. Utterly pointless and surely if the batmaker cared he would advise the customer not to waste willow on something he will get next to no benefit from.
kaartman
« Reply #3 on: May 13, 2016, 12:55:37 PM »
@smilley792 , thanks for confirming it.
Calzehbhoy
« Reply #4 on: May 13, 2016, 01:10:29 PM »
So, for weight reduction we could taper the edges on our bats, would potentially improve pickup and wouldn't effect performance in anyway?
« Reply #5 on: May 13, 2016, 01:39:13 PM »
I think the taper would have to be quite a lot more significant than 2mm for it to make any noticeable weight/pick up difference.
« Reply #6 on: May 13, 2016, 02:44:12 PM »
The taper is greater near the middle of the bat, smaller as you move away from the middle. If you were looking from the back, you'd see this sort of shape:    )(
It actually does have a big impact on pickup - probably leads to 0.5 to a full ounce of weight reduction.
Great bats.
« Reply #7 on: May 13, 2016, 02:51:07 PM »
Its kinda like concaving - too much and it could limit the hitting area...but a little bit, and you have a better pickup.
avkrish
« Reply #8 on: May 13, 2016, 04:14:09 PM »
Great bats.
Wouldn't this kind of tapering weaken the edges near the sweetspot?
« Reply #9 on: May 13, 2016, 04:22:57 PM »
Great to have the proof. Unlike concaving this isn't impacting the middle. Like Salix CTS/CTE bats before, it's a clever of creating a big edge (remember you are digging into a minimal concaved spine and 2mm into the blade might gain another 1mm in height) without the impact the pickup or the middle spread. Not sure it makes a huge difference but would be interesting to see a 4mm either side version with a gradual subtle curve, just to see how much could be taken off. Eventually you would end up with a GN Vortex! One for Streaky and the b3 boys to CAD!
« Reply #10 on: May 13, 2016, 04:42:04 PM »
I'd say its probably better just to have a smaller edge!
« Reply #11 on: May 13, 2016, 04:48:08 PM »
Salix did this a few years ago. It was called CTS and CTE. Details here:
http://www.salixcricketbats.com/downloads/bats_guide.pdf
« Reply #12 on: May 13, 2016, 06:42:04 PM »
Interesting article on the Salix bats.
Remember gray nicolls did an extreme version of this also a few years back. The vortex.
av8r
« Reply #13 on: May 17, 2016, 05:27:07 AM »
Received my Ghost...
2lb 9.8oz (after oiling and with a scuff sheet on)
41mm edge
66mm spine
The edges on mine taper between 2-3mm on each side. The tapering starts approximately 6mm from the face.
« Last Edit: May 17, 2016, 05:29:01 AM by av8r »
