Author Topic: Keeping Pads  (Read 5141 times)
Simmy
Keeping Pads
« on: June 22, 2016, 07:13:26 AM »
Ok So i need some new keeping pads as i have snapped the straps on mine.
The problem i have is my legs are massive and the strap are never long enough so only a few pads i have tried have fitted me.
The 1's that i have just broken are newbery SPS
the top strap is 40cm and fitted me just .
If anybody can measure there top strap in length and let me know how long it is i might be able to actually purchase some that fit me!
Thanks Simmy
The Cricket Boutique
    • The Cricket Boutique
Re: Keeping Pads
« Reply #1 on: June 22, 2016, 08:23:00 AM »
I will have a look shortly for you and let you know.  :)
Re: Keeping Pads
« Reply #2 on: June 22, 2016, 01:42:57 PM »
Straps on my Red Ink pads always seem very long to me, measured the top strap at about 38/39cm to the end of the velcro though so might not be much use.
Re: Keeping Pads
« Reply #3 on: June 22, 2016, 01:51:08 PM »
Salix Pod One are the longest pads we have currently, 39.5cm is the length of strap with velcro on it, there is another 3cm of 'tab' at the end of the strap.
shax12
Re: Keeping Pads
« Reply #4 on: June 22, 2016, 01:52:41 PM »
Don't know exact measurements but my Gray Nicolls keeping pads has very long straps. Will try getting exact measurement.
Re: Keeping Pads
« Reply #5 on: June 22, 2016, 02:04:09 PM »
From having a look I can only find about 1-2cm difference in most makes. However sometimes that extra cm makes all the difference  ;)
« Last Edit: June 22, 2016, 02:27:00 PM by TCB »
Re: Keeping Pads
« Reply #6 on: June 22, 2016, 02:18:57 PM »
@Simmy I'll check the Affinity ones mate...they may cater for the more rotund man 😉
Kieron_BT
Re: Keeping Pads
« Reply #7 on: June 22, 2016, 08:28:49 PM »
My B3 ones are massive if that helps?
Jlscarroll17
Re: Keeping Pads
« Reply #8 on: June 22, 2016, 09:12:24 PM »
GM are a nice fit both straps are very long
Simmy
Re: Keeping Pads
« Reply #9 on: June 23, 2016, 06:31:27 AM »
nope i had a pair of these last year with b3 gloves and both straps would not do up
No.4
Re: Keeping Pads
« Reply #10 on: June 23, 2016, 07:02:29 AM »
How about a pair of strettons? I'm sure George could makes the straps to whatever size you need them. Only thing is whether you mind wearing them under your trousers or not.
Re: Keeping Pads
« Reply #11 on: June 23, 2016, 09:01:11 AM »
Puma flextechs straps are 33cm, but the pads wrap around, and fit my 41cm calfs fine
Simmy
Re: Keeping Pads
« Reply #12 on: June 24, 2016, 10:46:03 AM »
Not gonna fit my 53cm calf tho lol
cricketbadger
Re: Keeping Pads
« Reply #13 on: June 24, 2016, 11:51:47 AM »
Why not buy a new pair of the ones you already had
TCA Coach
Rohan Garud
  • Will only use top of the range kit
Re: Keeping Pads
« Reply #14 on: August 28, 2016, 09:29:43 PM »
I have a pair of M&H CK22 WK Pads and the straps on those are absolutely enormous. They're top of the range pads too so its worth considering them
