Pages: [1] 2 3 ... 6
Author Topic: Batting pad weights database  (Read 99857 times)
0 Members and 11 Guests are viewing this topic.
adb club cricketer
« on: January 21, 2017, 07:59:52 PM »
For most of us, one of the key criteria to buying pads is the weight. While pictures and video reviews mostly can give us some idea about protection, unfortunately, weight is not evident and pad descriptions from the manufacturers or retailers don't have the weight specified either. Many pad descriptions might say "lightweight" but this is subjective e.g. 900 grams could be mentioned as light in the description, but for many these days, 800-900 could be average weight or  light could be only if less than 600/700 grams - again this is very subjective. So wanted to have one place where folks could put in their pad weights so fellow buyers will have one place to know weights before ordering online. I am starting with a set of pad weights I have compiled from few scattered posts around here or from friends.. hope fellow CBF mates would keep adding to this list in future when they get a pad themselves.
Couple of points to note when adding to this list:
1) Newer models of same pad could have different weight, so feel free to add weight with model year included if you have a newer model.
2) If not standard mens size (which is default), please make sure you mention the size e.g. youth, small mens, oversize mens etc.
Without further ado, here we go:
Weights (in grams per pad)
Aldred - 959g each
BDM Admiral Super test pads: 740 grams each pad
Bradbury players: 837 grams
Charlie French PPR1 - 937g each
Gray  Nics Powerbow 750  each pad 567g
GN Prestige: 926gms per pad
GN Select pads: 950 grams
GN Supernova 900:  860gms.
GN Legend: 908 grams
GN Omega 1500: 883 grams
GM OLE pads 1040g each
GM OLE Sponsored player pads 944g each (old version)
H4l 50/50 are 800 grams per pad
H4L Custom 1029g
Helygen Momentum - 988g each
Kookaburra Ignite Pro pads - 878 grams
Kookaburra Rogue 650 pads: 818 each pad
Kookaburra Kahuna 550 - 850 grams
Kookaburra Kahuna Players (2015 model) - 793 grams
Kook Kahuna Sponsored player pads 989g each.
Kookaburra Onyx Pro - 737 grams
Kookaburra Onyx 700 - 907 grams
M&H Distinction (old style) 929g
PRYZM Cricket pads : 760g
Puma evospeed 2, youth size: 640 grams
Puma Evospeed SL  mens pads - 690 grams
Puma Evopower SE Edition: 947 grams
Puma Iridium 6000 Felxtech pads with all velcro padding (high hat, knee roll and shin) included 766g each.
Puma Iridium 6000 Felxtech pads with knee roll padding remaining and high hat/shin padding removed 630g each.
Puma Platinum 6000 LE 860 grams
Reaper R1 - 974g each
Reaper R2 (not traditional looking though) - 656g each
Red Ink X1 - 869g each
SG RSD Prolite Youths pads: 680 grams each pad
SG Hilite pads: 828 grams each pad
SG Test batting Pads: 850 grams
SG VS 319 Ultimate batting pads: 793 grams
SG Litevate pads: 818 grams each pad
SS Test opener Mens size: 830 grams
SS Test Opener Youth size : 724 grams
Ten star pads: 780 grams each pad
« Last Edit: February 08, 2017, 02:05:16 AM by Cover_Drive »
adb club cricketer
Re: Batting pad weights database
« Reply #1 on: January 21, 2017, 08:01:09 PM »
adb club cricketer
« Reply #2 on: January 21, 2017, 08:01:37 PM »
Aldred - 959g each
adb club cricketer
« Reply #3 on: January 21, 2017, 08:03:13 PM »
adb club cricketer
« Reply #4 on: January 21, 2017, 08:03:39 PM »
H4L Custom 1029g
adb club cricketer
« Reply #5 on: January 21, 2017, 08:06:46 PM »
adb club cricketer
« Reply #6 on: January 21, 2017, 08:20:25 PM »
« Reply #7 on: January 21, 2017, 08:32:59 PM »
adb club cricketer
« Reply #8 on: January 21, 2017, 09:04:45 PM »
Probably helpful to update the OP as new weights come in as it will be a pain to search through the thread.
Also would be good to account for variation between pads and keep a note of how many pads were weighed to come up with that value, ie, 722 g (average 2 weighed) and add to it as more are weighed.
As a recovering MTB weight weenie, kitchen scales don't cut it either as they are often weigh off in their readings (boom tish) ;)
Good idea to keep adding to Original Post as it will reduce search burden/make more user friendly. As for posting the average weight, most pads weight diff will be off by few 10s of grams between left and right pads, so folks will know it is an approximate weight which is good enough I guess. At end of day we want to keep it simple to those adding. So either pad weight or average weight is fine.
Will post a summary current list of weights so far below.
« Last Edit: January 21, 2017, 09:07:31 PM by adb club cricketer »
adb club cricketer
« Reply #9 on: January 21, 2017, 09:09:55 PM »
Here is summary so far. Please add your entry to below list when you post (just to make it easier to search).
Aldred - 959g each
H4L Custom 1029g
« Last Edit: January 21, 2017, 09:22:20 PM by Buzz »
Jaffa
« Reply #10 on: January 21, 2017, 09:31:01 PM »
Aldred - 959g each
H4L Custom 1029g
GM OLE Sponsored player pads 944g each.
« Last Edit: January 21, 2017, 09:44:04 PM by Jaffa »
adb club cricketer
« Reply #11 on: January 22, 2017, 02:46:20 AM »
Here is summary so far. Please add your entry to below list when you post (just makes it easier to search).
Aldred - 959g each
H4L Custom 1029g
« Reply #12 on: January 22, 2017, 02:55:48 AM »
Thank you @adb club cricketer, I will also update the OP as we progress because this will become a multiple page topic.
simonmay5
« Reply #13 on: January 22, 2017, 03:08:26 AM »
H4l 50/50 are 800 grams per pad a
adb club cricketer
« Reply #14 on: January 24, 2017, 06:39:15 AM »
Aldred - 959g each
H4L Custom 1029g
