Author Topic: Kookaburra Kahuna Pro repair/return  (Read 3633 times)
renegademaster
« on: April 28, 2017, 07:10:17 AM »
Second net with this bat after plenty of knocking in (shop and me), two example of bad damage.
Decided not return it, repaired it as follows - would be interested to hear forum's expert response.
Removed clear scuff sheet, bit of mallet to reshape/flatten.
Applied small superglue to both cracks, removed excess (still v small ridge of glue on face crack).
Applied coat of oil.
When dry, applied Hammer Edge and some extra tape, pictured.
Anything else professional refurb/manufacturer would have done?
Replacement bat maybe. PVC wood glue.
EDIT: pics here
http://imgur.com/a/ksfic
« Last Edit: April 28, 2017, 07:39:50 AM by renegademaster »
Churchy1989
Re: Kookaburra Kahuna Pro repair/return
« Reply #1 on: April 28, 2017, 07:21:11 AM »
@renegademaster you need to upload your pictures to an online account like flikr then share them as a bbcode, this gives you code to put into your post to show your pictures.
Look forward to the pics. (unless its just me that can't see them).
« Reply #2 on: April 28, 2017, 07:23:23 AM »
Can't see the photos. I would imagine that the retailer/maker will have a pretty dim view of you attempting a repair first. This may have voided any warranty.
The uneven face probably points to inadequate knocking in. That's why it's best to knock in first then apply a scuff sheet.
renegademaster
« Reply #3 on: April 28, 2017, 07:44:24 AM »
Reupped them. You're probably right re knocking in. Which is odd given it was knocked in by both me and shop.
Re warranty - can always remove hammer edge and send back with clean face for them to have a look i think. Can sand off glue.
renegademaster
« Reply #4 on: April 28, 2017, 07:47:25 AM »
Pics don't work bru, you need the web address that ends .jpg or similar
What did you do to that poor bat? :)
Not sure any of the tape you put on is really doing anything, especially by the toe. Not sure what people would do on the face dent besides smear in some PVA maybe if the wood is split???
Thanks mate - agreed. Not sure what else there is to do apart from more knocking in.
renegademaster
« Reply #5 on: April 28, 2017, 08:13:12 AM »
Pics are here - can people see them?
« Reply #6 on: April 28, 2017, 08:23:04 AM »
'Tis but a scratch.
renegademaster
« Reply #7 on: April 28, 2017, 08:34:48 AM »
'Tis but a scratch.
Hahaha. Really? Nothing to worry about? I am in love with this bat, hence why i don't want a replacement. 2 8 and stupidly big edges.
ppccopener
« Reply #8 on: April 28, 2017, 08:44:13 AM »
I wouldn't worry too much. there is (im pretty sure) a link between big bats, big edged and profile bats, being less durable now than before because of the pressing or drying process(or both)
so...it's kind of a hazard of modern bats, if it goes well just look after it as much as possible
bats years ago lasted a lot longer..but the performance was not there as much from the start
« Reply #9 on: April 28, 2017, 08:58:41 AM »
You wouldn't get a replacement if that was sent back to kookaburra in my opinion.
Toe damage like that can only be sustained through badly mistiming a hard drive at a Yorker. Cricket bats are designed to hit the ball out of the middle, they inherently have weaker areas and are not invincible. The weakest areas (edges and toe) are not strictly covered under a warranty as to put it bluntly the manufacturer will say you are supposed to use the middle. That being said I've never come across a manufacturer who has refused a free 'warranty' repair in this situation, and they will replace if the damage in not repairable.
As for the face dent there is an argument to say the bat has been under prepared (and the manufacturer will leave you and the retailer to sort that between yourselves) but also given the nature of the marking on the scuff sheet, there's an argument to say the bat has been hitting poor quality cricket balls extremely hard. All new bats should be played in Progressively with throw downs/gentle nets against old/soft balls. even the most robust/played in bats are not immune from a hard cheap ball that is basically a rock painted red.
renegademaster
« Reply #10 on: April 28, 2017, 09:01:45 AM »
Thanks man - appreciate wise words. Especially given how much these things cost nowadays.
Here she is in all here glory - look at those edges on a 2 8!
http://imgur.com/a/he5s0
renegademaster
« Reply #11 on: April 28, 2017, 09:07:10 AM »
This sounds spot on from start to finish, and thank you for your time and expert view. This was used in a fast indoor net against a very rapid bowler (for club level). Guessing 80mph. Didn't even think about ball quality. Starting to understand concept of a 'net bat' now.
« Reply #12 on: April 28, 2017, 09:53:09 AM »
Yup, dent suggest not enough knocking in or cheap balls.
Toe damage might lead to worse but not in the short term.
Both can be made to look nicer with some sanding, gluing etc, but IMO that doesn't really have a great deal of practical effect.
