Author Topic: Dislocated finger  (Read 4433 times)
Dislocated finger
« on: July 12, 2017, 08:58:17 AM »
Morning all
Last Thursday I dislocated the little finger on my right hand. It was only the end joint, with my fingertip facing the wrong way.
Being the imbecile I am, I popped it back in and continued playing.
Fast forward nearly a week and I've still got it buddy strapped to my ring finger. It's still slightly swollen and the end joint has limited movement. It's still rather sore and makes me jump if I knock it.
Has anyone else done similar? What is the rough recovery time for a dislocated finger, and will it work "normally" again?
Cam
x
Re: Dislocated finger
« Reply #1 on: July 12, 2017, 08:59:32 AM »
6 weeks.
You should go to A&E.
« Reply #2 on: July 12, 2017, 09:09:01 AM »
Hospital time
Boondougal
« Reply #3 on: July 12, 2017, 09:24:33 AM »
As my Dad would have said in such circumstances when I was younger.... let me have a look how bad it is.....I'll get the saw.
jamielsn15
« Reply #4 on: July 12, 2017, 09:43:29 AM »
Get it checked. Biggest concern with popping it back yourself trapping nerves, etc. I did the same to my thumb, popped it back in while fielding, went to A&E that evening. Best to be sure!
Spanky
« Reply #5 on: July 12, 2017, 09:45:12 AM »
Dislocated the end of my little finger last season in the pre match warm up, went straight to hospital to have it popped back into position. Then returned back to the game to see the end of our innings, had tea then went out to field.
I was back playing the week after however kept it strapped up for the first few games when fielding, it was tender for a good few weeks afterwards.
« Reply #6 on: July 12, 2017, 09:53:33 AM »
Perfect, cheers.
I popped it back in and carried on bowling!
Played a couple of games since with it strapped, batting is a bit sore, bowling is fine and I'm being hidden in the field to avoid making it worse.
Strap it and have a dose of Man-Up before each game it is. There's no way I'm risking losing my place in the side for our Cup Final because of my little finger!
jimmy23
« Reply #7 on: July 12, 2017, 10:01:31 AM »
Could be some tendon damage in the end knuckle.
Most probably all they will do at a&e is put a single half finger splint on that will allow it to knit back into a regular 'straight' position.
rickjames
« Reply #8 on: July 12, 2017, 10:06:23 AM »
Popped by ring finger late last year out deep, swelled up like a balloon, went to A&E and they popped it back in. Still feels a bit painful every now and then but have to live with it.
Churchy1989
« Reply #9 on: July 12, 2017, 10:16:40 AM »
@WalkingWicket37 you need to keep it as straight as possible in a strap, occasionally do finger stretches a few times a day, it takes time, mine was 6-8 weeks, the nurse said 'i know you cricket boys will still play, just be carefull'
felix
« Reply #10 on: July 12, 2017, 12:48:10 PM »
Being such an incompetent fielder I think I must have done this half a dozen times over a few decades and every time I popped it straight back in while high on adrenalin.   Not sure it's the right thing to do but I'd imagine it's easier to do this if you grit your teeth before swelling sets in.  I'll probably have crippling arthritis when I get (even) older.  I don't think I ever missed a game because of this, though had to hide a bit in the field, except for the one time the bone came through the skin, eurrgh  :(  - that took several weeks to recover.
« Reply #11 on: July 12, 2017, 02:29:22 PM »
Dislocated my forefinger at the first joint the ball hit the tip of my finger after  a  short while the pain went i carried on playing but from the joint to the tip it flopped around so at the end of the season I went to AE they put in strapping for 6 weeks to keep it still
« Reply #12 on: July 12, 2017, 03:28:43 PM »
Best to get it checked. My dislocation ended up being a small fracture as well (despite no pain)... I was told to take it easy for 4-6 weeks if I wanted to avoid surgery
blindowl
« Reply #13 on: July 12, 2017, 03:46:53 PM »
oooph   I feel a bit sick reading this thread. Ive broken fingers doing judo but for me a dislocation seems so much worse!   A lad at the school I work at dislocated his knee and waited on the ground for over an hour for an ambulance to get him.
LBWCandidate
« Reply #14 on: July 12, 2017, 04:23:45 PM »
Get it checked. No ifs and buts!
