Few Made Over The Weekend
Author Topic: Few Made Over The Weekend  (Read 6470 times)
Churchy1989
« on: February 19, 2018, 01:23:02 PM »
Okay, so this could go under the Fugly Section! - Mid Middle - Spine into the toe.
Tried to copy my XX SSH - But a few alteration to get the pick up good.
Boondougal
Re: Few Made Over The Weekend
« Reply #1 on: February 19, 2018, 02:54:39 PM »
Looks brilliant!
Andythomo21
« Reply #2 on: February 19, 2018, 02:57:47 PM »
XX copy looks a cracking effort mate.👍
Churchy1989
« Reply #3 on: February 19, 2018, 04:10:34 PM »
Its pretty close, and slightly lighter on the scales than the XX.
Very happy as the Spine is dead straight - the other one is 95% straight!
But, the pick up on the Fugly is amazing!
Blank Bats
    • Blank Bats
« Reply #4 on: February 19, 2018, 04:22:24 PM »
Great effort
Blank Bats
http://www.blankbats.co.uk
« Reply #5 on: February 19, 2018, 04:31:02 PM »
Sussex cricket bats is go!
Umi
« Reply #6 on: February 19, 2018, 06:47:42 PM »
Great attempt mate, it’s definitely an accomplishment
JK Lewis
« Reply #7 on: February 19, 2018, 07:24:22 PM »
Love it mate! Quality. What's the specs?
« Reply #8 on: February 19, 2018, 08:21:02 PM »
Excellent
jamesisapayne
« Reply #9 on: February 19, 2018, 11:54:08 PM »
Great effort @Churchy1989 well done - second bat profile looks absolutely superb!
Have you been making these with traditional tools?
sgcricket
« Reply #10 on: February 20, 2018, 04:53:21 AM »
Looks great! Keep up the good work
Churchy1989
« Reply #11 on: February 20, 2018, 09:00:17 AM »
Missed this last night, will get the ruler out!
Drawknife to start - then a Spokeshave - different spoke for the shoulder. My plane is not sharp enough to use - and i am a bit lazy to sharpen.
Spoke does lovely long clean shavings - happy to take my time.
Question, why use a rasp for the handle? Whats wrong with a spoke then a sand?
My 4 little babies - Almost have more i have made than bought!
« Last Edit: February 20, 2018, 09:03:22 AM by Churchy1989 »
JK Lewis
« Reply #12 on: February 20, 2018, 05:48:53 PM »
Why the range of sizes @Churchy1989 ? Do you have customers lined up already?! Hope so. What's your branding going to look like?
Churchy1989
« Reply #13 on: February 20, 2018, 08:45:49 PM »
So the First 'Fugly' one:-
5mm shorter than a SH
Shoulder: 17mm
Edge: 39.5mm
Spine: 65.2mm
Toe: 21.9mm
Middle Toe: 35m
Width: 109mm (shhh)
Weight: 2lbs 11oz on the nose (1 grip no scuff).
Next my XX Copy:-
SSH
Shoulder: 16.3mm
Edge: 34.7mm
Spine: 65.3mm
Toe: 21.5mm
Middle Toe: 29.8m
Width: 108.5mm (shhh)
Weight: 2lbs 11oz on the nose again!(1 grip no scuff).
Whilst i am here i will do the Butterfly:-
SH
Shoulder: 18.6mm
Edge: 38.2mm
Spine: 61.2mm
Toe: 26.3mm
Middle Toe: 33.2m
Width: 109.6mm (shhh)
Weight: 2lbs.11oz & 5/8ths (1 grip no scuff).
So i made the XX copy as the XX is just so lovely...and wanted to test my skills - very happy with the result.
The Butterfly i copied off a custom H4L that had great balance - also very happy with the result. Its slightly smaller but the original was 2lbs.13oz i think @simonmay5 can confirm.
The fugly, i just started shaping and just went with the flow to get a great pickup - also the first one i have used a spine all the way into the toe.
Sizing of the Fugly was just be not measuring where i was cutting the toe - noted for next time! (The bat on the left is the same size as the Butterfly - normal SH).
I need to do a final sand and buy a machine to buff next pay day, then these will be Demo bats most likely. Have 3 more to shape this weekend if i get time.
Designs are coming along but not there - probably a month or 2 off!
tuffers007
« Reply #14 on: February 21, 2018, 10:04:02 AM »
they look great!!
i struggle blending the shoulders. due to this i take the easier option of using a file then sanding. all credit to you for doing it the correct way!
congrats on a job well done.
