GM Factory Visit
Pages: 1 ... 14 15 [16]
Author Topic: GM Factory Visit  (Read 55067 times)
Edward Lowy
    • Gunn & Moore Cricket
Re: GM Factory Visit
« Reply #225 on: October 29, 2018, 09:30:31 AM »
Even Jesus had his critics Edward!
Sounds like everyone had a fantastic time. Ive never had a brand new GM before but after hearing all the positive feedback from the 5 that went i think 2019 will be the year. @Six Sixes Cricket can you line me up something nice please?
Well this is true!
We had a great day, looking forward to the next one!
Kind regards
Edward
Managing Director
Unicorn Products Ltd
LateBloomer
« Reply #226 on: October 29, 2018, 11:06:18 AM »
Certainly @LateBloomer , which model currently takes your fancy?
I like the look of the Mythos, slightly shorter blade is that right? But am open to your suggestions
As a reference - the balance of that Chase I had from you is perfect for me
Calzehbhoy
« Reply #227 on: October 29, 2018, 08:39:43 PM »
With the Signature looking the stand out bat, particularly at the price point does this sit above the 808 in that it goes through the ‘better’ two press process or only through the single press?
Sorry, I’m still not 100% on where these sit in the range.
« Reply #228 on: October 29, 2018, 09:15:27 PM »
Signature is about 707 range, and therefore doesn’t get the second press.
They said it changed the feel, didn’t say it made the bat any better. Didnt say it made it worse though.
Was the reason to make the lower range bats last longer, or simply that a single press saves time?
Calzehbhoy
« Reply #229 on: October 29, 2018, 09:47:11 PM »
Sorry I assumed that it must produce a better product if was completed only on the higher end bats.
sarg
    • CricketBatInfo
« Reply #230 on: October 30, 2018, 03:00:06 AM »
Signature and 707 are relative to each other and below 808, so i'm guessing one press. That said i've reviewed 606's and signatures and found no issue with their press. I think I said n a recent review I could tell the pressing had improved.
Loved reading most of this thread and well done to the lads for the write-up and GM for a great day and full transparency. Great company.
« Reply #231 on: October 30, 2018, 09:40:56 AM »
@Edward Lowy please can you explain the two styles of press you use?
What is the difference between the way you press bats 808 and upwards and the lower end offerings, and what does this achieve?
Thank you in advance
« Reply #232 on: October 30, 2018, 10:32:50 AM »
I would like to know why your bats aren’t bowed. Is there a particular reason for this?
alexhilly1492
« Reply #233 on: October 30, 2018, 11:59:32 AM »
i forgot to ask this
however
when the handles are fitted they are set slightly forward which gives them a hint of a shape
I think this is a  quirk of a GM bat and something the brand has decided to do
there are some bats in the range that have a bow, i think the Zelos is onw
BB: 7-4-9-5, 7.3-0-29-5
Edward Lowy
« Reply #234 on: October 30, 2018, 03:51:16 PM »
I think there may have been something lost in translation here - all full size bats are pressed the same irrespective of grade. We use two presses, one hydraulic and one mechanical as over time we have found that a combination of the both provides the best and most consistent pressing.
Kind regards
Edward
Managing Director
Edward Lowy
« Reply #235 on: October 30, 2018, 03:54:16 PM »
Zelos blade is bowed and, yes, as mentioned elsewhere, all GM bats have a "set" to the handle / blade which gives a natural curve.
Try one Guru, it will be a life changing event!
Kind regards
Edward
Managing Director
Edward Lowy
« Reply #236 on: October 30, 2018, 03:55:01 PM »
however
You after my job?!  :D :D :D
Managing Director
alexhilly1492
« Reply #237 on: October 30, 2018, 04:05:49 PM »
Not at all!
Although if theres anything going...  :D
« Last Edit: October 30, 2018, 06:57:07 PM by alexhilly1492 »
« Reply #238 on: October 30, 2018, 04:11:39 PM »
Kind regards
Edward
So GM only press in one way then?? I.E a signature bat is pressed exactly the same way and the same amount of times as an OLE
Yorkershire
« Reply #239 on: October 30, 2018, 04:24:41 PM »
Not at all!
Although it’s theres anything going...  :D
In the Darts division or Snooker/Pool cues?    :D :D :D :D
