Weight reduction
Pages: [1] 2 3
Author Topic: Weight reduction  (Read 6473 times)
ozcfa
Weight reduction
« on: December 15, 2018, 05:31:49 AM »
i am getting some weight reduced from my new AS bat, hopefully 4oz off from 2.11 to 2.7
The bat is big with 44mm max edges and 35mm max toe. So I think there is some excess fat
I have approached Cooper Cricket and Brisbane Bat Refurbishment. Anyone here dealt with them
before.
Need some guidance from people who have experience of getting weight reduced. I
Its a beautiful bat and don’t want it to be ruined.
Link to the thread with bat photos
http://custombats.co.uk/cbforum/index.php?topic=44912.75
Re: Weight reduction
« Reply #1 on: December 15, 2018, 05:35:09 AM »
4 oz is a crazy amount of weight to lose. Dont
waste your money and just send it back
ozcfa
« Reply #2 on: December 15, 2018, 06:17:22 AM »
Yep, 4oz is too much... I assume your comment  is based on your experience, is it?
Cholrudee
« Reply #3 on: December 15, 2018, 07:09:16 AM »
Best option is to sell it as which ever path you do take it will cost you money.
ozcfa
« Reply #4 on: December 15, 2018, 07:39:25 AM »
Definitely, will sell it or keep it as it is. But I want to make it useable.
Interested in hearing people’s experiences who have gone through this process
« Reply #5 on: December 15, 2018, 07:53:08 AM »
I've had 2 ounces taken out of a bat and it was never the same
    • Neon Cricket
« Reply #6 on: December 15, 2018, 08:16:00 AM »
Unless you’re intending on turning it into a Harrow 4oz is a substantial amount of willow. If you’re still able to just return it then that’s your best bet imo
Turn Of Pace
« Reply #7 on: December 15, 2018, 08:59:39 AM »
It’s virtually impossible for even the most skilled bat maker to take 4oz out of a bat and still maintain the integrity of the bat. Send it back or sell it are your only options if you’re not going to use it I’m afraid.
« Reply #8 on: December 15, 2018, 09:54:51 AM »
Looking at the photos you could lose a lot of weight from that toe - it looks so thick and almost unfinished.
That would change the pick up an awful lot so you may not need so much weight off as you think
That said I’ve had weight off an old GM Flare and it was never the same
A  bat maker’s judgement is the optimum bat trying to get out of each cleft - if this cleft was destined to have made a massive bat at 2.7 it would already be one and it wouldn’t have been quite so reasonably priced
« Reply #9 on: December 15, 2018, 10:16:08 AM »
Do agree 4oz is a lot to remove  but having reduced bats by 4oz including down from 2lb 11 to 2lb 7 ounce  for myself and others without it being detrimental to the  bat  by removing the wood first off the toe and then  evenly off the back until  wearing gloves the bats pickup feels right in the hands if your bat has a full back or minimal concaving a batmaker should easily achieve your required bat weight.
« Last Edit: December 15, 2018, 11:39:12 AM by Seniorplayer »
    • Neon Cricket
« Reply #10 on: December 15, 2018, 10:33:36 AM »
Do agree 4oz is a lot to remove  but having reduced bats by 4oz including down from 2lb 11 to 2lb 7 ounce  for myself and others without it being detrimental to the  bat  by removing the wood first of the toe and then  evenly off the back until  wearing gloves the bats pickup feels right in the hands if your bat has a full back or minimal concaving a batmaker should easily archive  your required bat weight.
Which tool did you find best to use @Seniorplayer? I presume it was a pretty big bat in the first place!
« Reply #11 on: December 15, 2018, 11:37:17 AM »
Spokeshave Blockplane orbital sander double handle rasp and mouse sander
Forgot to write didn't remove wood from the spine.
« Last Edit: December 15, 2018, 11:46:04 AM by Seniorplayer »
« Reply #12 on: December 15, 2018, 06:14:59 PM »
4oz is a chunk of weight
But that toe looks ripe for a bit of weight removal
Then take the edges down, and re shape the profile
It’s gonna be a different bat tho
Sitonit
« Reply #13 on: December 15, 2018, 06:23:52 PM »
before.
Talk to that J P Gavan guy, may be?
With the bulk in the shape of these monsters, I think it’s possible to easily take off 3 Oz
You start off from the bottom and chisel the toe down 18 mm flat all across thus removing the spine up to three inches from the bottom up. That’s about an Oz
Then you trim down the edges to 35 mm and reduce the bulk by scalloping and creating a reasonable concaving.
That’s about another 2 Oz
And you end up with a 2.8
Otherwise, hit the gym and build some muscles to be able to enjoy playing with this beast.
And finally, the best option in my opinion.
You can also use this as a practice bat in the nets. Many, many international pros use a much heavier bat in the nets to strengthen their batting muscles which helps them increase the bat speed when they play with their actual and lighter match bats.
KW9221
« Reply #14 on: December 15, 2018, 08:22:24 PM »
Last year I sent my Kippax for 5 ounces weight reduction and it was fine. They made it into duckbill shape and it picks up so much better. My advice is don’t go for dead weight and try to shape it for better and lighter pick up.
http://custombats.co.uk/cbforum/index.php?topic=41358.0
« Last Edit: December 15, 2018, 08:24:19 PM by KW9221 »
Instagram: Cricketer_guru
Pages: [1] 2 3
