Author Topic: does anyone know how to get the stamping off the side of the bats  (Read 2763 times)
hazant0803
hi recently purchased a ss ton maximus and i would like to get the edge stamping off i was wondering what were a couple ways to get it off, preferably not sanding it would be great
Mfarank
Re: does anyone know how to get the stamping off the side of the bats
« Reply #1 on: January 02, 2019, 05:37:57 AM »
Other than sanding unfortunately theres no other way to get it off. U can maybe hide it by putting some tape or stickers over it
« Reply #2 on: January 02, 2019, 09:51:41 AM »
You could gently sand the stamping out if you  don't want a  slight dip  where the stamping  are sand either side of the stamping blending the sanding into the edge.
« Reply #3 on: January 02, 2019, 11:13:38 AM »
Could it be bleached off or something similar, you'd obviopusly strill have the indented area but it'd be less visable without narrowing your bat :)
JK Lewis
« Reply #4 on: January 02, 2019, 02:02:41 PM »
If you take it to a joinery workshop, or to a batmaker, they could skim it off with their planer/thicknesser. That way you can take of 0.1mm or whatever at a time, evenly, and keep the the loss of width to a minimum. I use such a machine to get my bats down to exactly 108mm and as long as the blades are sharp it should leave a very smooth finish.
« Reply #5 on: January 02, 2019, 03:39:00 PM »
It's not  that easy to skim an edge with a planer also you have to skim from both toe and shoulder to prevent ends chipping.
JK Lewis
« Reply #6 on: January 02, 2019, 03:55:36 PM »
It's true there's a risk whatever you do but I've not had any trouble with the thicknesser personally. You would just set it to 107.9mm or whatever and slot the bat in, then reset yo 107.8 and run the other side through.
Sitonit
« Reply #7 on: January 02, 2019, 08:39:43 PM »
Or perhaps apply some water resistant paint in the timber tone.
SD
« Reply #8 on: February 03, 2019, 11:16:23 PM »
My last match bat lasted 4 seasons and by the end, I had managed to edge the ball enough times to remove the stamping on the inside edge.
adb club cricketer
« Reply #9 on: February 04, 2019, 01:11:55 AM »
Some tape with a color that is close to the willow color is the best bet. Moreover,  that would make you would look like a pro  :D
Not a fan of shaving off width at that point even if it is just 0.1 mm as that is usually where the sweet spot is and psychologically you don't want to feel you have less width there...
