Show us yer pants!
Pages: [1] 2 3
Author Topic: Show us yer pants!  (Read 7871 times)
Wozaboxa
Show us yer pants!
« on: January 12, 2020, 12:12:08 AM »
As the title says, show me your pants, or rather tell me what you use for cup support. At the moment I use the slazenger sports direct specials but I don't find the fit very good. Is it a case of the tried and trust jock strap or is there a hidden gem for the most comfortable cricket under crackers ever and I'm missing out?
Jaffa
Re: Show us yer pants!
« Reply #1 on: January 12, 2020, 12:30:32 AM »
I use Shock Doctor compression shorts. So comfy you only have to adjust your box out of habit rather than necessity. A little overdone but definitely miles better than others I've tried including Aeros which are second on the list.
https://www.ebay.co.uk/itm/SHOCK-DOCTOR-Core-Compression-Shorts-Groin-Guard-/222950022742?var=&hash=item33e8db5e56
But they are a little expensive so I might go for something like this next time.
https://www.ebay.co.uk/itm/Carbon-Digi-cam-Smuggling-Duds-SD-Pro-Range-Compression-Shorts-with-Groin-Cup-/142871537446?var=&hash=item2143cea726
alexhilly1492
« Reply #2 on: January 12, 2020, 02:39:37 AM »
Nike pro compression shorts box inside then white football shorts with thighpads over the top
Like the feeling of box on flesh knowing it's there (I have forgotten it before)
Tried alsorts of bespoke box shorts/jock strap but fine the valve is most comfortable and supportive
BB: 7-4-9-5, 7.3-0-29-5
« Reply #3 on: January 12, 2020, 04:39:34 AM »
Tried different ones but these are my favorites: https://www.aerocricket.com/equipment/clothing/aero-shorts.html
tommo256
« Reply #4 on: January 12, 2020, 09:15:47 AM »
I wear budgy smugglers!
Wozaboxa
« Reply #5 on: January 12, 2020, 12:39:41 PM »
Cheers all, I've some nike compression shorts already so I'll give them a go and check out the others!
You have to protect the davina McCall's after all!!
richthekeeper
« Reply #6 on: January 25, 2020, 01:28:56 PM »
I have the aero box shorts but find they make my thigh pad slide around so I tend to bat in the aero briefs.
I also really like a pair of American Football shorts I bought in the US - they have a ‘cup’ which is very similar to a cricket box but more comfy for me. They’re like this: https://www.target.com/p/franklin-sports-youth-compression-short-with-cup-s-m/-/A-15100492 very similar to shock doctor
« Reply #7 on: January 25, 2020, 01:59:47 PM »
Does anybody just put it in a sock and then leave the flap bit over the top?
Psi
« Reply #8 on: January 25, 2020, 02:17:13 PM »
I don't think you're protecting the right bits if you put it in your socks 😂
« Reply #9 on: January 25, 2020, 02:24:14 PM »
Strange you’d think but I know a fair few people who use a sock to hold their box, then just put it in their boxers or briefs
Coach
« Reply #10 on: March 10, 2020, 06:48:45 AM »
The box in a sock is a classic club cricketers go to, but surprisingly used by quite a few on the county circuit! Personally I’ve always just gone with the old school jockstrap but in a pinch the sock is trustworthy
Mfarank
« Reply #11 on: March 10, 2020, 07:42:35 AM »
I have a pair of Slazenger shorts from SD and about 6 of JAWZ gears compression shorts. I find them to be very breathable and comfortable for the cruel UAE weather
SurreySam
« Reply #13 on: March 10, 2020, 04:31:37 PM »
My aging jockstrap and GN box combo needed updating/replacing.  So I recently purchased the Shockdoctor shorts with included Bioflex cup, I also purchased an Aero Groin Protector to see what works out best for me.
I like the Shorts as the cup pocket is quite ergonomic, allowing these large cups to fit well and not impede too much on the shorts functionality (see below picture fitted with the Aero Groin Protector).
The Bioflex cup offers good protection if you caught a blow front on, yet if the ball comes in at more of an angle, the protection offered is less so. The volume of space in the large Bioflex cup size is ok but the senior sized Aero Groin Protector is bigger and felt better for me when testing out protection with the mallet.  However I did prefer the fitting between the thighs of the Bioflex cup, it was narrower and flexible. So if you were doing a lot of running, I imagine the Bioflex cup would work out better and it also has breathing slots to help you from getting 'betty swallocks'.
For now though, I'm going to run with the Shockdoctor shorts and Aero Groin Protector combination.
« Reply #14 on: March 10, 2020, 04:46:38 PM »
"when testing out protection with the mallet"
You should try the shock Dr aircore hardcup
Pages: [1] 2 3
