How often has it happened?
Pages: [1] 2 3 4
Author Topic: How often has it happened?  (Read 9699 times)
« on: March 24, 2021, 09:57:37 AM »
Bats feeling lighter or heavier with the course of time, even being stored in the same area.
Are muscles too a factor to consider?
How often has this happened? Thanks
Kai
Re: How often has it happened?
« Reply #1 on: March 24, 2021, 10:56:05 AM »
I think over the winter bats definitely feel heavier especially in the UK but I think a lot of it is just in our head and also based on form. Yeah, I think your strength changing can definitely affect it too, I noticed my Kookaburra felt lighter since I am still growing but then again maybe its just in my head ;)
« Reply #2 on: March 24, 2021, 11:36:20 AM »
Is your question how often do bats change weight based on moisture levels or how often would you expect your muscular strength to change enough to effect your perception of the weight of the bat?
« Reply #3 on: March 24, 2021, 11:46:54 AM »
Put your bats on the scales. They could have gained some moisture in the winter.
Or you could have to do some work in the gym...
Bearing in mind there has been a pretty wet winter and we have been in lockdown, I am expecting both.
« Reply #4 on: March 24, 2021, 11:48:26 AM »
Enjoy your cricket, thanks for sharing your thought
« Reply #5 on: March 24, 2021, 11:51:05 AM »
You mean to say gained a lot of weight? 😀😃
« Reply #6 on: March 24, 2021, 11:52:53 AM »
Both, actually, guessing both have to do with each other
Tom
    • www.cricketinsight.co.uk
« Reply #7 on: March 24, 2021, 12:39:37 PM »
It's totally possible that 1 bat has gained moisture (and therefore weight), and 1 bat has lost moisture.
Depends on the humidity of the room they were in and the moisture content of the willow before you left them.
SurreySam
« Reply #8 on: March 24, 2021, 12:49:36 PM »
I also find that storing bats in a garage/environment with more humidity, the willow fibers can expand and roughen the surface finish a little.
jayralh
« Reply #9 on: March 24, 2021, 12:52:21 PM »
Is storing bats in attic/loft a good idea?
Kai
« Reply #10 on: March 24, 2021, 12:56:43 PM »
Noticed this too... I bought a GM Noir Signature last year at the end of the season and left it in the garage and picked it up recently and the finishing seemed worse than when I originally got it.
Jordansh
« Reply #11 on: March 24, 2021, 01:00:50 PM »
Is this not just normal fluctuations in how wood is?
Would end of season care with an oiling etc avoid this?
SouthpawMark
« Reply #12 on: March 24, 2021, 01:21:34 PM »
Can honestly say I’ve never noticed a change in weight of any bat I have e be ever owned, and there have been a LOT.
Bat perv.
« Reply #13 on: March 24, 2021, 01:27:16 PM »
Makes sense,
I'm also trying to understand the influence of muscles to bat's weights, pickups and feeling
« Reply #14 on: March 24, 2021, 01:34:19 PM »
I only store them in my room, at room temperature which is at least at comfortable feel.
Non of them felt dry at all, even butterfly had a very light coat and later had to wipe oil.
Pages: [1] 2 3 4
