England v New Zealand
Pages: 1 ... 5 6 [7] 8 9 ... 19
Author Topic: England v New Zealand  (Read 53769 times)
Kai
Re: England v New Zealand
« Reply #90 on: June 05, 2022, 08:19:10 AM »
How important is counterattacking? I agree that its important to be able to hold your end and play the gritty knock but I felt like the pressure Stokes put back on New Zealand has been key to the chase so far though he did ride his luck with being bowled of a no-ball.
six and out
    • MKCC website
« Reply #91 on: June 05, 2022, 09:53:23 AM »
Certainly set up for a great finish.
The pessimist in me says that we have a very long tail and 1 more wicket and it's trouble plus its going to be ideal bowling conditions this morning.
But must be positive!!! And Root and Foakes are going to knock this off, as it's only 60 left, the balls already 65 overs old and worse case Broad and Potts are worth at least 30 between them. Easy!!
Bungle
« Reply #92 on: June 05, 2022, 09:57:46 AM »
How much can Potts bat? Obviously better than the other 3 bowlers but is he going to be able to get himself in? Especially with quite a lot of nerves if it comes down to him needing to stay out there/score runs to win the game.
ppccopener
« Reply #93 on: June 05, 2022, 10:27:52 AM »
While Foakes is with Root I don’t think Joe will be distracted. I guess with the tail anything could happen batting last.
 Broad is complete hit or miss could slap 20 or be out first ball
rickjames
« Reply #94 on: June 05, 2022, 10:59:07 AM »
We don't deserve Joe Root
thegowerwaft
« Reply #95 on: June 05, 2022, 11:16:53 AM »
Truly impressive from Root and Foakes. The knock from Stokes yesterday helped set the tone. A very impressive achievement.
Bungle
« Reply #96 on: June 05, 2022, 12:23:53 PM »
He is just so good, hoping that he keeps this up now that he doesn't have the burden of captaincy. Also very impressed with how Foakes played the situation superbly, Buttler would have hit 2 fours in a row then got out and left Root with the tail.
ppccopener
« Reply #97 on: June 05, 2022, 02:16:51 PM »
Yes totally agree with the above. stokes will be aggressive and not intimidated by the match situation. At the same time you need intelligent batsmen who can absorb pressure over 5 days.
So you need both types. I really do think that number 3 spot is to protect our middle order going forward.
Not 100 per cent sure who that is but an out of position player is not the answer.
An improved Sibley with more scoring areas may be a possibility in that one two three position.
« Reply #98 on: June 05, 2022, 02:18:45 PM »
Lees, Sibley, Bohannon would be my shout, with Compton in consideration if he maintains form.
billyb
« Reply #99 on: June 05, 2022, 03:24:31 PM »
Amazing result!
Foakes knows how to bat properly. Root is a genius. On we go!
six and out
    • MKCC website
« Reply #100 on: June 05, 2022, 03:50:40 PM »
Always be positive! Root is the Goat and Foakes a proper batter.
beaver5
« Reply #101 on: June 05, 2022, 04:14:18 PM »
If Root is a definite 4, then our biggest issues are 3 & 5. Pope and Bairstow aren't good enough for 3, so one or both should go. Personally I'd have Brooks at 5. After that it's find a solid no.3 - Hain, Bohannon, Abell or move Crawley to 3 and find another opener.
Manormanic
« Reply #102 on: June 05, 2022, 04:27:19 PM »
Radical solution but... one of the issues Foakes faces at 7 ahead of 10, 10, jack and jack is that he is an accumulator rather than an aggressive player.
He bats up the order for Surrey (admittedly only 5) but could he perhaps do a job at 3 or 4? That would help so many of our other best options fit in more naturally.
fros23
« Reply #103 on: June 05, 2022, 04:42:14 PM »
Only Sanga and Stewart have played more than 10 test innings batting at 3 and keeping, so there must be a good reason for that.
Twitter - @fros231
Bungle
« Reply #104 on: June 05, 2022, 04:44:08 PM »
Not sure about that, did you see his shot in the first innings? We tried this with Bairstow and it just doesn't work.
