Edge Boning Tool
Author Topic: Edge Boning Tool  (Read 4537 times)
Bungle
Edge Boning Tool
« on: December 09, 2022, 10:04:40 AM »
What does everyone use for boning the edges of new bats? Is there any effective tool to use?
JTtaylor145
Re: Edge Boning Tool
« Reply #1 on: December 09, 2022, 10:12:52 AM »
There are a few you can use, counter of a work surface, rolling pin, grip cone or one of Elviar's tools.  Gentle knocking in will also round your edges. Personally I use a work surface I have at home and a rolling pin. Depends of your level of patience/skill.
Thanks
JT
« Reply #2 on: December 09, 2022, 10:18:53 AM »
I use the edge of my bath.
« Reply #3 on: December 09, 2022, 10:19:22 AM »
I use the side of a bath. Works fantastic
« Reply #4 on: December 09, 2022, 10:27:02 AM »
I've been using the rounded middle section of an LV mallet, seems to work fine.
« Reply #5 on: December 09, 2022, 11:00:42 AM »
Basically anything harder than the willow itself, which will compress and round it over. I use a piece of dense hardwood similar to Lignum, which I've rounded into a rod and use on all my bats prior to sending them out. Edges are slightly sanded too before this. Although the modern trend is obviously to keep them sharp so the edge appears bigger, especially with the flatter faces.
velvetsky01
« Reply #6 on: December 09, 2022, 11:41:27 AM »
I have a round piece of LV works well
HS: 119*
Best Bowling 7.4-1-32-6
« Reply #7 on: December 09, 2022, 01:29:10 PM »
Knew I forgot something that trip I had!
Bungle
« Reply #8 on: December 09, 2022, 02:24:08 PM »
Now that's definitely not something I have thought of!
« Reply #9 on: December 09, 2022, 02:25:52 PM »
I'll send it with that  Butterfly 😆
« Reply #10 on: December 09, 2022, 06:30:43 PM »
I’m over next week so that works 😁
« Reply #11 on: December 09, 2022, 07:43:59 PM »
I use an Elviars boning tool, not cheap for a non bat maker but they are excellent for doing the job perfectly
wasimbhai
« Reply #12 on: December 09, 2022, 09:41:04 PM »
Rolling Pin..works great
Chompy9760
« Reply #13 on: December 10, 2022, 03:20:07 AM »
I have used a length of 1" galv waterpipe, but the surface has to be very smooth.  For that reason I've since used some large, chromed sockets out of my toolkit, with some beeswax or linseed oil for lube.
« Reply #14 on: December 10, 2022, 07:58:16 AM »
Where's @FattusCattus when you need him 😆
