Author Topic: Knocking question  (Read 2273 times)
Cricket_PTY
Knocking question
« on: January 19, 2023, 08:29:23 AM »
Guys if u use a quality clear scuff sheet, does using it reduces or should reduce the knocking in time?
I did bought a bat recenlty here in India, shop did machine knock, i did abut 2 more hours of knocking (30 mins on each edge, 30 mins in the toe area and 30 mins on the face)
I am about to put a clear scuff sheet... but i am not 100% sure if this is the appropiate time to do it or should knock a bit more...
Will like to hear ur advice guys...
    • Neon Cricket
Re: Knocking question
« Reply #1 on: January 19, 2023, 08:45:52 AM »
Tap a ball up on the bat a few times, if there's deep seam marks keep going, if not whack a sheet on and get in the nets - sounds like you should have done enough unless the bat is particularly soft!
« Reply #2 on: January 19, 2023, 08:58:17 AM »
Yep, wouldn't add the sheet until you're satisfied you've done enough knocking in.
Cricket_PTY
« Reply #3 on: January 19, 2023, 09:10:06 AM »
In ur experience (that is def more than me) are SS bats considered "soft" ?
    • Neon Cricket
« Reply #4 on: January 19, 2023, 09:19:18 AM »
Don't really have much SS experience I'm afraid! It will vary from bat to bat though, the best way to check is if a leather ball leaves a deep seam mark or not when tapping up - if it does just spend a bit more time knocking in until it doesn't!
Cricket_PTY
« Reply #5 on: January 19, 2023, 09:25:45 AM »
Thanks !!!
