Author Topic: I had a bit of spare time yesterday  (Read 6839 times)
ajmw89
  • 4XI ornament
    • Wright Cricket
« on: November 19, 2012, 03:35:05 PM »
So i shaped another bat.
Finished weight is 2lb10oz. 30mm edges. A little bit of concaving.
I'll get some more pictures up from my camera. These are just phone pictures.
Re: I had a bit of spare time yesterday
« Reply #1 on: November 19, 2012, 04:02:22 PM »
Very nice! Seems to be quite an offset edge there! 8) Is it just me, or is the spine slightly off centre? Might just be the camera angle! Looks a tiny bit Distinction-ish to me!
ajmw89
  • 4XI ornament
    • Wright Cricket
« Reply #2 on: November 19, 2012, 04:05:09 PM »
I think it might just be the angle. I measured it, and it came out right. I didn't intend to offset the edge, i guess it just happened! Picks up nice though!
mad_abt_cricket
« Reply #3 on: November 19, 2012, 05:14:57 PM »
Very nice shape. Mate what do you use for sanding?
Karan62
  • Colts
« Reply #4 on: November 19, 2012, 05:19:55 PM »
thats a great profile :) the middle seems MAHOOSIVE :D
ajmw89
  • 4XI ornament
    • Wright Cricket
« Reply #5 on: November 19, 2012, 06:34:15 PM »
Orbital sander for the face and edges. Hand for the rest. Go through the grits from 40 to 1200 then polish and oil. Not entirely happy with one or two bits. Just need to give it another sand and polish really...
mad_abt_cricket
« Reply #6 on: November 19, 2012, 06:45:49 PM »
Try to do the back too with the orbital sander. It is extremely time consuming to do with hands and pretty hard to get desired finish. I do only the fine grade sanding with hands.
mad_abt_cricket
« Reply #7 on: November 19, 2012, 06:48:12 PM »
Also the greenish Color around the toe is from a very fine grit sanding I guess. I had similar experience while finishing my first bat as the fine grit gets deposited in the very fine scratches made by the tools.
« Reply #8 on: November 19, 2012, 06:57:19 PM »
Sounds like you need to go through the grits slower. I've never experienced grit ending up in scratches. Either that or the sandpaper your using is either poor or too much heat caused by excessive pressure is causing the adhesive on the paper to fail.
To me it looks as if the tools have gouged a couple of marks out the back. Possibly need sharpening or adjusting to make finer cuts. Would make sanding alot easier aswell
ajmw89
  • 4XI ornament
    • Wright Cricket
« Reply #9 on: November 19, 2012, 07:00:48 PM »
I struggle to get the sander up the back with the concaving. Got a detail sander somewhere but only have 240 grit sheets for it.
ajmw89
  • 4XI ornament
    • Wright Cricket
« Reply #10 on: November 19, 2012, 07:03:06 PM »
The colour on the toe is from where it got knocked out my hands and onto the grass by my dogs... Thankfully I kept the rest of it off the ground. Lol.
mad_abt_cricket
« Reply #11 on: November 19, 2012, 07:27:21 PM »
Ah then alright.. I guessed it wrong.. :)
mad_abt_cricket
« Reply #12 on: November 19, 2012, 07:33:25 PM »
You are right! I did the complete sanding of my first bat via hand and changed the grits before getting rid of fine scratches. The fine sanding paper of around 1500 has a very thin layer of fine grit and I ended up rubbing quite a bit to get rid of those scratches instead they filled with the grit Color.
norbs
« Reply #13 on: November 20, 2012, 04:33:40 PM »
ajmw89 call me for some tips mate, my number is on the website
The fine grits you end up with are way too high
« Last Edit: November 20, 2012, 04:35:28 PM by norbs »
ajmw89
  • 4XI ornament
    • Wright Cricket
« Reply #14 on: November 20, 2012, 04:35:38 PM »
Thanks, I'll be sure to!
