Mongoose mmi3 specs
Author Topic: Mongoose mmi3 specs  (Read 6282 times)
tom line
Mongoose mmi3 specs
« on: September 01, 2014, 10:18:15 PM »
Hi all wasnt sure where to put this but, I was just wondering whether anyone knew what the measurements are for the length of the blade and and the length of the handle was on the mongoose mmi3 bat is as I have a part made and have decided I would like to try replicating it.
Thanks all
Pelican042
  • Best bowling 1-4
Re: Mongoose mmi3 specs
« Reply #1 on: September 02, 2014, 10:08:27 AM »
Basically equal, keep trying unil yup find it's the right size to cover most of your regular hitting area
"Just remember the best shot in cricket is the leave" *leaves on middle stump*
« Reply #2 on: September 02, 2014, 10:11:49 AM »
I'll try and remember to measure mine for you tonight buddy
tom line
« Reply #3 on: September 02, 2014, 11:50:33 AM »
Cheers I will bear this in mind while cutting it down
[/quote]
If you could that would be great cheers buddy
cricketrob
« Reply #4 on: September 02, 2014, 12:25:11 PM »
39cm from toe to base of the shoulder
42.5 cm from toe to the bottom off the handle (roughly where the grip starts)
42cm length of the handle
They might not be 100% accurate but it's as accurate as I could see.
tom line
« Reply #5 on: September 02, 2014, 12:35:20 PM »
Thanks mate a great help
« Reply #6 on: September 02, 2014, 12:58:39 PM »
Saved me a job, cheers boss!
cricketrob
« Reply #7 on: September 02, 2014, 12:59:58 PM »
No worries lads
jwebber86
« Reply #8 on: September 02, 2014, 04:40:13 PM »
i was going to measure mine tonight but its in the attic glad somebody beat me to it
@james_webber
@dunstercricket
« Reply #9 on: September 02, 2014, 04:43:30 PM »
If you are working with a part made, surely you won't be able to replicate an MMi?
« Reply #10 on: September 02, 2014, 04:45:54 PM »
I can only presume he plans to shape the willow I to the extra large handle, as opposed to an extra large handle that the mongoose has?
tom line
« Reply #11 on: September 02, 2014, 04:50:34 PM »
I plan to cut the blade down so shaping the rest of the handle out of willow I believe this is actually done on the mongoose as the handle is spliced in the handle to allow maximum hitting zone
« Reply #12 on: September 02, 2014, 04:53:17 PM »
Correct a mongoose has a reverse splice. But if your part made has already been handled, there is only so much you can do isn't there? Removing willow around that area will create a weak point, which i think maybe was part of the reason behind the reverse splice on the mongoose?
cricketrob
« Reply #13 on: September 02, 2014, 05:44:24 PM »
I've seen this sort of thing done before, it seemed to come out ok but getting the mongoose shape was apparently very hard and the toe and edge came out a lot smaller.
tom line
« Reply #14 on: September 02, 2014, 07:13:14 PM »
I plan to double twine to increase the strength of the join just incase I hope it isn't a problem but of it breaks I suppose it is a lesson learnt and the standard of cricket I play I doubt it will break especially as we use £20 balls in our league so there not bat breakers
