Pages: 1 ... 7 8 [9] 10 11 ... 19
Author Topic: The Winter Bat Refurb Thread  (Read 94327 times)
SteffanLangholz
    • Teams webpage
Re: The Winter Bat Refurb Thread
« Reply #120 on: January 10, 2016, 05:00:33 PM »
Some tlc to an this epic piece of wood.
Sendt fra min ONE E1003 med Tapatalk
« Last Edit: January 10, 2016, 08:33:13 PM by SteffanLangholz »
tom line
« Reply #121 on: January 10, 2016, 08:26:31 PM »
A woodworm black label to refurb and repair a toe crack. Nice grains and good pick up. It's just one of those bats that has a special something about it wen you pick it up
SteffanLangholz
    • Teams webpage
« Reply #122 on: January 10, 2016, 08:34:46 PM »
How did this go? I just did sort of the same, but with moulded colored epoxy resin.. That will likely shatter tho..
Here is the B3 from my previous update. My first attempt to build up the missing piece of wood involves some pva and sawdust mixed together. Going to give it a couple of days to dry and then sand it on Saturday.
wayward_hayward
« Reply #123 on: January 10, 2016, 08:38:12 PM »
Badly, the mixture had too much sawdust so didn't set and was very heavy, ruining the balance. I have removed it and sorted out a couple of toe cracks that ended fixing. I haven't decided what to do regarding the missing chunk.
Twitter @wayward_hayward
SteffanLangholz
    • Teams webpage
« Reply #124 on: January 10, 2016, 08:39:36 PM »
Would you be able to donor it, had you had another bat? How?
« Reply #125 on: January 10, 2016, 08:41:05 PM »
Not sure how good your wood working skills are, but I have an old kook with the same but missing.
It won't be an easy repair, but with patience and skill you may be able to remove another section from the kook to glue and dowel into that area.
wayward_hayward
« Reply #126 on: January 10, 2016, 08:45:16 PM »
Yeah, I could cut out a piece from another bat and fit it into position where the missing chunk is. Not sure it is worth it as the chunk missing isn't that large.
wayward_hayward
« Reply #127 on: January 10, 2016, 08:46:46 PM »
What have you got Chris? I could be interested if it's a testing repair job.
« Reply #128 on: January 10, 2016, 08:49:49 PM »
I'm working away this week, so once back will signing out and send you some pics.
Yours for delivery cost.
wayward_hayward
« Reply #129 on: January 10, 2016, 08:59:09 PM »
Ok mate, look forward to seeing it.
« Reply #130 on: January 10, 2016, 09:19:51 PM »
If I can butt in. I am a former cabinet maker and it is a fairly simple job. Use a marking gauge to score a line parallel to the edge of the bat. With a tri square and marking knife/pencil/craft knife score across the grain to the edge. This should form a rectangle around the damaged area  With a 1 inch (or wider) chisel remove the damaged area so you have a rectangle. Remove the material so you have a flat base (dead easy in a soft, straight grained material like willow). Cut a slightly larger rectangle out of the donor bat and glue in place. The key to this is to make some angled blocks to go in the jaws of the vice/cramps. Then remove the excess willow with a sharp chisel/knife. Finally sand flush.
For a slightly better repair, undercut the edges of the rectangular recess and cut the same chamfer on the 2 corresponding edges of the donor piece.
SteffanLangholz
    • Teams webpage
« Reply #131 on: January 10, 2016, 09:23:15 PM »
Will definately try this at some stage.. Stacking donors atm..
« Reply #132 on: January 10, 2016, 09:41:05 PM »
Although I agree in principle in what you've said. There is one slight issue I can across when I did the exact same.
The face of a cricket bat is pressed and then further knocked in
The donor bat will usually be pressed and knocked in
When you make it slightly larger, and then sand down, you sand away the pressed part.
You then end up with a soft corner off the bat, basically unpressed, knocking in will harden said part, but it then sits below the rest of the bat as its compressed.
What the solution is I don't know.
« Reply #133 on: January 10, 2016, 09:43:44 PM »
Fair comment. In that case cut a slice off of the face of the donor bat the same thickness as the missing piece
tom line
« Reply #134 on: January 16, 2016, 08:26:22 PM »
Now finished the repair and clean up on the woodworm
