Pages: 1 ... 6 7 [8] 9 10 ... 19
Author Topic: The Winter Bat Refurb Thread  (Read 94329 times)
cricketrob
Re: The Winter Bat Refurb Thread
« Reply #105 on: August 18, 2015, 04:41:08 PM »
Thanks @cricketrob
I used an orbital sander for all my sanding and a buffer drill piece for the buffing. I used David's at Norfolk Bats today as it much quicker to use. I use the following sandpaper grit for the majority of bats 120, 180, 240, 320 and 400. I may skip 120 if the bat is in good condition.
Thanks mate I will have to give it a do in a couple of bats I have
wayward_hayward
« Reply #106 on: August 18, 2015, 04:56:10 PM »
Look forward to seeing the results.
Twitter @wayward_hayward
Nmcgee
« Reply #107 on: August 19, 2015, 12:30:58 AM »
I went over to see David at Norfolk Bats this morning to grab a couple of sets of stickers (also a few others bits which I will post elsewhere). I have given this bat a coat of oil and then a generous buff since the last photos. Buffing the bat makes it wonderfully smooth and silky, I can nearly see a reflection on it! All its needs is a scuff sheet and edge tape to protect the surface cracks and toe damage. I'm pretty confident it still has a few hundred runs left in it and does not feel dead when bouncing a ball on it. Ambitious and not rubbish, result!
Still don't get it @Nmcgee?
Refurbishing bats is not my cup of tea but I will certainly say @wayward_hayward , you do a very fine job and these bats have come up very well.
Back yourself.
wayward_hayward
« Reply #108 on: October 27, 2015, 01:32:10 PM »
With the clocks going back in the UK and the nights getting earlier and earlier, it must mean it's time to resurrect this thread.
I received this today from eBay. Stickered up as a B3 3 stripe bat, although I'm not 100% if it's genuine. The seller was from Nottingham so could be a refurb job by them. Any ideas @thedoctor?
Damage to the RH inside edge/toe and also some delamination above the area. Not an easy first project of the winter.
« Reply #109 on: October 27, 2015, 01:43:31 PM »
@wayward_hayward - have you checked for the model number on the binding? Pretty sure refurbs of other brands don't get stripes or series stickers either. Looks like a DB1 to me. Asked the @The Doctor ?
« Last Edit: October 27, 2015, 01:45:11 PM by uknsaunders »
rich041187
« Reply #110 on: October 27, 2015, 01:49:34 PM »
I thought the ebay listing had a newbury sticker on the end of the handle??
« Reply #111 on: October 27, 2015, 01:51:04 PM »
Wierd. Why did the eBay add show a newbery sticker on top of the handle?
May have been a wrong picture added
With the cork handle, full sticker set and grains matching the grade. It looks a genuine 3 stripe series b3 to me.!
Centurion
« Reply #112 on: October 27, 2015, 01:55:25 PM »
Looks genuine to me. Nice profile on that too.
W.G. Grace
« Reply #113 on: October 27, 2015, 01:58:49 PM »
As i said before, the photo that showed the Newbery sticker had a different grip on too, I presumed it was just a wrong photo that slipped in, easily done.
wayward_hayward
« Reply #114 on: October 27, 2015, 01:59:12 PM »
The eBay listing did have a Newbery handle sticker. It must have been a different bat as this bat has the B3 sticker as shown above. I am still sceptical as the bat has no number on the handle or binding......
Damage aside, it seems a solid bat!
wayward_hayward
« Reply #115 on: December 16, 2015, 08:45:14 PM »
Here is the B3 from my previous update. My first attempt to build up the missing piece of wood involves some pva and sawdust mixed together. Going to give it a couple of days to dry and then sand it on Saturday.
« Reply #116 on: December 16, 2015, 09:45:07 PM »
If it works. Does that mean we can use chipboard to make bats out of?
wayward_hayward
« Reply #117 on: December 17, 2015, 07:44:22 AM »
Well I suppose it could go one of two ways....
The sawdust I used is pure willow from a previous refurb so hoping it will do the trick.
« Reply #118 on: December 17, 2015, 07:51:45 AM »
I wish you luck but I would be surprised if it lasts. Why didn't you splice in a piece of willow from a donor bat?
wayward_hayward
« Reply #119 on: December 17, 2015, 08:04:19 AM »
Simple answer is because I don't have a donor bat at the minute and i wanted to see how successful this attempt was. I will give this a go and if it isn't successful, I will attempt to glue a donor piece in place.
