Author Topic: How do you know if you are a top or bottom hand player?  (Read 2730 times)
MrCricket321
  • Colts
« on: April 18, 2015, 02:27:22 AM »
Is there any ways that you can find out that if you are a top or bottom hand player
skip1973
Re: How do you know if you are a top or bottom hand player?
« Reply #1 on: April 18, 2015, 03:09:11 AM »
Are you a filthy slogger that mainly hits to cow corner?
Number4
« Reply #2 on: April 18, 2015, 03:16:38 AM »
There is an easy way to tell.
Stand on your front leg and lift your back leg off the ground then lean forward and put your top hand behind your head and your bottom hand out by your side and then do the same with your bottom hand and then tell me which way you over balance while doing it.
MrCricket321
  • Colts
« Reply #3 on: April 18, 2015, 05:06:13 AM »
Both on the same foot?
MrCricket321
  • Colts
« Reply #4 on: April 18, 2015, 05:06:44 AM »
to the right (fyi i am a righthanded batsman)
« Last Edit: April 18, 2015, 05:18:08 AM by MrCricket321 »
MrCricket321
  • Colts
« Reply #5 on: April 18, 2015, 05:08:17 AM »
But i dont think i am over balancing when i dont both the actions- i can balance pretty well when i am doing both the things that you said
Number4
« Reply #6 on: April 18, 2015, 05:20:35 AM »
 Yep there's your answer.... You are gullible  :D
MrCricket321
  • Colts
« Reply #7 on: April 18, 2015, 05:49:52 AM »
good job mate good job...
« Reply #8 on: April 18, 2015, 06:00:09 AM »
If you are good hitting through the off side off the front foot, especially through the drive then you are a good top handed player.
If you hit the ball more towards the leg side the your bottom hand is taking over.
« Reply #9 on: April 18, 2015, 06:02:14 AM »
Or you have a natural advantage like I do I'm left handed but bat right handed so my top hand always takes over as it the most powerful
MrCricket321
  • Colts
« Reply #10 on: April 18, 2015, 06:32:43 AM »
Cool thanks @Buzz - i mostly play to the off side with the occaional pull to the leg
Ragamuffin
« Reply #11 on: April 18, 2015, 06:54:15 AM »
If you can play inside out, you are bottom handed.
« Reply #12 on: April 18, 2015, 07:05:31 AM »
Do you score Loadsa runs?
If yes, then who gives a monkeys
« Reply #13 on: April 18, 2015, 07:39:06 AM »
Bottom handed players always have their grips sliding halfway up the handle. Top handed players never need to realign their grips.
« Last Edit: April 18, 2015, 07:41:54 AM by Gurujames »
« Reply #14 on: April 18, 2015, 09:16:49 AM »
If you bat like me and grip the bat tight with your bottom hand and  give the ball a wack to the legside you are a bottom Hand player.
« Last Edit: April 18, 2015, 09:21:14 AM by Seniorplayer »
