Author Topic: Affinity Toro vs. H4L WarBird.  (Read 4373 times)
Silver Bullet
« on: February 18, 2016, 05:07:48 PM »
Due to constraints on time, I'm primarily planning on playing T-20 cricket as a mid-lower order bat.
Affinity and H4L are probably my two favorite brands by some distance. For people, that have seen both bats in the flesh, how would you compare them ?
thecord
Re: Affinity Toro vs. H4L WarBird.
« Reply #1 on: February 18, 2016, 05:34:23 PM »
Don't believe the Toro is being made any more
Silver Bullet
« Reply #2 on: February 18, 2016, 05:53:34 PM »
Yup, there's a couple of lightly used ones I can pick up.
JB
« Reply #3 on: February 18, 2016, 06:14:49 PM »
I've had quite a few bats from each maker. I've got a Toro but not had a Warbird. The middle will be lower on the Toro, pick up on mine which is 2.13 is excellent though. Love all the bats that I've had from each maker they've all performed very well. You can't really go wrong, pick which one you like the look of better or even better buy one of each!
Leno
« Reply #4 on: February 18, 2016, 06:15:33 PM »
Just pick the one with the best stickers because they will both be cannons
simonmay5
« Reply #5 on: February 18, 2016, 09:24:38 PM »
To me they are both very good bats but having used both I did not like the toe on the toro as when running the bat in found it can get stuck as it's got a very square toe the warbird has a round toe so no issues there and I believe h4l are making some of the best bats around at the moment
« Reply #6 on: February 18, 2016, 09:35:25 PM »
Without turning this into a Matt/H4L fanboy zone, I second this comment!
You honestly won't regret it if you buy a Warbird  :)
Silver Bullet
« Reply #7 on: February 18, 2016, 09:35:51 PM »
Anyone know if the blade length is the same on both bats ?
« Reply #8 on: February 18, 2016, 09:46:13 PM »
I believe the Toro is a slightly shorter blade than the Warbird.
« Reply #9 on: February 18, 2016, 09:48:14 PM »
With a square toe.....  ;)
« Reply #10 on: February 18, 2016, 09:48:55 PM »
It's T20 what are you doing running in order to run ur bat in anyway 😳
#DealingInBoundaries
northernboy1987
« Reply #11 on: February 18, 2016, 09:50:31 PM »
Tom, is there any chance of Marcus making more Toro's do you think?
Sent from my SM-G900F using Tapatalk
« Reply #12 on: February 18, 2016, 10:15:09 PM »
It's one to ask him, it's often the case of if there's a demand for a product you consider fulfilling it but then I'm not the one making them Haha.
northernboy1987
« Reply #13 on: February 18, 2016, 10:19:18 PM »
Well I'd certainly consider buying one, get your tools out man 😂
« Reply #14 on: February 18, 2016, 10:19:30 PM »
If you follow Marcus various feeds, there's something coming for this summer, it may not be a Toro but it's aimed at t20 if I understand him right.
As for the thread. My toro is awesome.
Ping is beautiful, pickup is fantastic, and if you run it in face down not edge down I can't see you having the digging in issues mentioned.!
