Pages: [1] 2 3 4
Author Topic: Duds  (Read 13041 times)
Sitonit
Duds
« on: July 11, 2017, 12:39:09 PM »
We have talked much about praising and appreciating our purchased bats.
Did anyone ever have a disappointment with a new or used bat?
Re: Duds
« Reply #1 on: July 11, 2017, 12:45:32 PM »
I've had 2 MSR's which were both planks. One was a g1 the other a butterfly. A GM Apex original was also poor.
Re: Duds
« Reply #2 on: July 11, 2017, 12:46:25 PM »
Yes, many of us, and one brand in particular did pretty badly in that respect. Just search for the SAF topic on here.
Re: Duds
« Reply #3 on: July 11, 2017, 12:55:07 PM »
Only real disappointment I've had in a good while was a sports direct sale GN which just felt a bit rubbish when netting, small middle and vibrations through the handle even after a good knocking in and a few nets. Suspect it was just pressed too hard, maybe it'll make someone a decent bat if they give it the time to open up, but I just moved it on via eBay.
Re: Duds
« Reply #4 on: July 11, 2017, 01:01:24 PM »
Not in recent times but Have had two both GNs one I took back to the sports retail store and explained it didn't ping  but they didn't  want to know so I contacted my insurance helpline who wrote to them I got  my money back on returning the bat.
The second i sent back to GN  with a covering letter after phoning first stating  the bat  didn't  ping they swopped it for a like for like new bat no problem.
Biggie Smalls
Re: Duds
« Reply #5 on: July 11, 2017, 02:16:15 PM »
Bought a 3lb puma/millichamp when i was 14 . Looked amazing grain wise and was top of the line g1 . They wouldn't let me use a mallet to ping test it in store , but they ping tested a bunch in front of me and gave me the 'best' one which i bought in good faith . Anyway it was an absolute plank . Vibrated like hell and sounded like Dennis Lillee's aluminum bat when you managed to find the miniscule middle . I took it back to the store .... they laughed in shock( embarrassment? ) when they ping tested it again , apologised profusely,  replaced the bat and i ended up with an absolute belter . Sometimes you get a dud . Moral to that story - i still occasionally buy bats from the same store till this day but i always say to them ' if you don't let me ping test it myself I'll take my money elsewhere'.
Calzehbhoy
Re: Duds
« Reply #6 on: July 11, 2017, 02:52:53 PM »
I bought a top of the range GN Velocity a few years back with the carbon handle. It was absolutely terrible. I took it back to Robertsbridge 3 times and each time they refuse to do anything to it. I ended up chucking it in a skip it was that bad.
Re: Duds
« Reply #7 on: July 11, 2017, 03:58:19 PM »
Performance free B3s. Once in a blue moon, I'd use them against cheap net balls in nets. They are so hard pressed you can drive nails with them.
Never again, I say!
Re: Duds
« Reply #8 on: July 11, 2017, 04:11:16 PM »
Never again, I say!
Also had a bad b3. Just didn't sound right. Sold on & put it down to a one off.
thedon
Re: Duds
« Reply #9 on: July 11, 2017, 05:11:23 PM »
I've had a few gm's 909's. Pressed hard. I would never buy gm again
Re: Duds
« Reply #10 on: July 11, 2017, 05:28:36 PM »
I've often found the duds turn into absolute guns as soon as they're used by a teammate :-[
KW9221
Re: Duds
« Reply #11 on: July 11, 2017, 06:05:26 PM »
I have also had bad experience with GM so I won't be buying GM anymore.
Instagram: Cricketer_guru
JB
Re: Duds
« Reply #12 on: July 11, 2017, 06:27:53 PM »
I've got a GN Omega LE Robertsbridge made that doesn't sound great! Very tinny sound to it
Re: Duds
« Reply #13 on: July 11, 2017, 06:34:56 PM »
A few rock hard GMs off all grades. Shame as I did used to like and rely on a good GM
Had a grays that was awful. Shop agreed and sent back to grays, grays returned it claiming it was fine and they wouldn't refund/replace.
Amusingky.you could see the mark in the stickers where they had repressed it to about 1inch from toe to. Just below splice was pressed a few mm lower and you could. See it plain as day).
They also manage to. Burn one of the edges(can only presume steaming dents out went wrong)
It was a dud and ended up as a lad at our clubs indoor bat. Tape ball all it was useful for.
Ajdal
Re: Duds
« Reply #14 on: July 12, 2017, 06:39:43 AM »
A 2014/15 GM 808 Icon, quite heavy for it's size and pressed hard as a rock. And a Spartan CG Authority(top of the line?), soft as soft gets and not in a good way. The response was terrible when bouncing a ball on it and the balance was terrible, felt like all the weight was near the toe. Very heavy concaving on it too.
Both these bats were not mine but a friend's, bought blind online.
Pages: [1] 2 3 4
