Does anyone use a middling bat?
Author Topic: Does anyone use a middling bat?  (Read 5246 times)
AC93WK
« on: October 31, 2018, 11:58:20 AM »
Just wondering if any of you guys use one in nets? Looking into getting something along these lines, any recommendations? Cheers
Mel Jessop
Re: Does anyone use a middling bat?
« Reply #1 on: October 31, 2018, 12:02:43 PM »
Chat to John at Red Ink.
Biggie Smalls
« Reply #2 on: October 31, 2018, 01:01:57 PM »
I use one every now and then if i feel im not finding the middle well.
My only suggestions would be get one made with the same type of handle on your match bat ....and try to get it in the same weight range . For me there's no point using one if it weighs 2.2 and throws your timing off.
Churchy1989
« Reply #3 on: October 31, 2018, 03:37:03 PM »
Interestingly (or not) one of my club mates (who scores all the runs) just takes the stump out of the ground and uses that if he thinks he isn't middling everything.
« Reply #4 on: October 31, 2018, 03:43:09 PM »
Agree with the Bigs! If you use a 2'10 in the middle, ensure the middling bat is around 2'10!
And don't worry about the ping or quality. The whole idea is to practice finding the middle of the bat....not to get boundaries.
 Mine weighs 2'10 so there are some heavier ones around.
Churchy1989
« Reply #5 on: October 31, 2018, 03:45:26 PM »
I remembered seeing a cheap one....
http://phantomcricket.com/product/technique-training-cricket-bat/
It is Kashmir willow..
« Reply #6 on: October 31, 2018, 04:05:56 PM »
Please note: These bats are currently only offered in Kashmir willow. Bat weights will vary – at present we are unable to accommodate specific requests for weights.
The above would put me off unless they could give an idea of weight range! Imagine if they send you 2'5 and you wanted a 2'12! Not good unless they can at least get within a couple of ounces?
If they can get within a couple of ounces, then you can add an extra grip and a scuff sheet and toe guard to add a bit more weight.
« Reply #7 on: October 31, 2018, 08:25:15 PM »
I can make you one up to mirror the weight and middle of your match bat. £55 inc uk postage
KW9221
« Reply #8 on: October 31, 2018, 08:32:32 PM »
I have one By XX and it is amazing.
Instagram: Cricketer_guru
Mattsky
« Reply #9 on: October 31, 2018, 08:46:52 PM »
Thing is with middling bats... if you can't  find the middle on your grown-up bat, what makes you think you can find it on one half the size?   ;)
Peter O' Toole
Rob580
« Reply #10 on: October 31, 2018, 10:01:07 PM »
Mate of mine has one that’s only about 2 lbs, with 10oz of lead taped on the back, spread out to give a decent enough balance.
Given it’s still got 40mm edges to get the weight to 2lbs, it goes well enough to give you an idea of if you’ve timed it.
Might be a solution if you can pick one up cheap?
« Reply #11 on: November 01, 2018, 06:09:41 AM »
Exactly what I've done to make mine, took a bandsaw to an old bat with a broken toe and made up the weight with lead on the back. Goes like a train with all the lead behind the middle! Not really convinced they're that useful a training tool though.
AC93WK
« Reply #12 on: November 01, 2018, 10:52:53 AM »
Thanks for the advice guys, did think about cutting an old bat down a few of you suggested, shall have a good look into it all.
« Reply #13 on: November 01, 2018, 10:57:30 AM »
I am not sure the weight is a massive issue, I have a 2lbs2 one, the point of them is to get you to play the ball under your eyes more.
Still they are a great thing to use and John's offer is a bargain.
« Reply #14 on: November 01, 2018, 11:47:58 AM »
Out of interest what is his offer?
