Pages: 1 ... 3 4 [5] 6 7 ... 19
Author Topic: The Winter Bat Refurb Thread  (Read 94462 times)
Re: The Winter Bat Refurb Thread
« Reply #60 on: February 25, 2015, 01:52:17 PM »
Woodworking guides I have seen all recommend sanding with the grain. Will try sanding across the grain to see if that helps, those pesky willow strips are a PITA. Thanks for the tip Jake!
It is largely irrelevant (based on my relatively limited knowledge) when using an inflatable drum sander like i do, or when hand-sanding (not including the fine grits which may strip the willow up no matter how careful you are) but when using a DIY sander like Ryans, or a sheet sander like i used to, then going across definitely seemed to help.
« Last Edit: February 25, 2015, 02:02:12 PM by Vitas Cricket »
FvanN
« Reply #61 on: February 25, 2015, 07:25:11 PM »
Just finished my two CA's. Well apart from sticking the grips on.
« Reply #62 on: February 25, 2015, 09:46:55 PM »
Not a refurb as such but I've just finished playing with my SS Yuvi 20-20 (well, that's what it used to be!)
It went from this
To this
DACD 1987
« Reply #63 on: March 01, 2015, 06:22:39 PM »
Some very impressive bits of work here guys.
What are you using to give the bats their final buffing?
wayward_hayward
« Reply #64 on: March 01, 2015, 06:34:15 PM »
I use something similar to this @DACD 1987, fit it to your drill and bingo.
http://www.toolstation.com/m/part.html?p=11969
Twitter @wayward_hayward
DACD 1987
« Reply #65 on: March 01, 2015, 06:44:31 PM »
That's excellent many thanks
Your posts have inspired me to have a go myself.  :D
wayward_hayward
« Reply #66 on: March 01, 2015, 06:58:40 PM »
That's amazing to hear, I have really enjoyed sharing my projects and talking about how to improve.
« Last Edit: March 01, 2015, 08:41:28 PM by wayward_hayward »
tom line
« Reply #67 on: March 02, 2015, 07:56:33 PM »
Did this refurb a couple of weeks ago. Salix wasp 2.11
This is how it turned out after a bit of rough sanding (120) with the orbital sander and then 180, 240,320 400 then 800 by hand. I finished it with lord Sheraton wood balsam
wayward_hayward
« Reply #68 on: March 07, 2015, 10:50:37 AM »
Chilled morning cheering on the Irish with couple of repairs. 2 bats require some glue on the face and the other is on a diet and reshaping.
wayward_hayward
« Reply #69 on: March 08, 2015, 02:42:37 PM »
I have worked on reducing and reshaping a bat that started out life at around 2'12 and felt very bottom heavy. I decided to create a duck bill profile, which has ended up very prominent to create a more manageable pick up. Considering this was my first attempt, i'm pretty happy with the result. The final weight with two grips is 2'10 so around 2 to 3 oz has been removed while still keeping a full profile.
Checking both edges for symmetry
Apart from the knot, it's not a bad looking bit of wood.
Boondougal
« Reply #70 on: March 08, 2015, 11:12:28 PM »
Nice job!
wayward_hayward
« Reply #71 on: March 10, 2015, 09:29:51 PM »
Latest bat in need of some TLC, the bat is a Bumble Bee which was run by a team mate. The bat is huge, I suspect it is a narrow width. I think the bat is Indian made, any clue who made it from the photos?
KIPPERS
« Last Edit: March 10, 2015, 11:49:12 PM by KIPPERS »
KIPPERS
« Reply #73 on: March 13, 2015, 05:51:56 PM »
A couple of new bunnies to tickle up while watching the Rugby
tejasapatel
« Reply #74 on: March 20, 2015, 02:15:05 AM »
For yearly refurb..should I remove the scuff sheets from all my bats? Or I shouldn't have to worry about oiling the part covered by scuff sheet.
- Ian Botham
